Connection Error
namalepross
Outlook 2013 64 bit
:confused::confused::confused:Why do I keep getting a cOnnection Error message whenever I attempt to send out messages from my Samsung using Outlook App?
Help Help..............
I checked with a fellow MVP who uses a droid and he suspects it's two factor authentication causing the issues.
M Outlook 2010 Error: Your IMAP server closed the connection Using Outlook.com accounts in Outlook 1
M Outlook Email Connection Error Using Outlook 3
e_a_g_l_e_p_i All of a sudden I lost connection to Gmail servers Using Outlook 8
W Encrypted connection to server refused Using Outlook 0
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
C Last Connection Using Outlook.com accounts in Outlook 1
K Work Email - Calander Connection to Outlook.com Using Outlook 2
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
E IMAP server closed the connection Using Outlook 2
P Outlook Connection Issues Using Outlook 3
Z connection to Lotus Notes Using Outlook 4
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
E intermittent "Your imap server closed the connection" messages Using Outlook 6
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
N Outlooking not connecting. Connection present Using Outlook 1
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
S Remote connection to bcm BCM (Business Contact Manager) 1
D Event on connection mode change? Outlook VBA and Custom Forms 2
P Database connection problems BCM (Business Contact Manager) 1
J BCM connection problem BCM (Business Contact Manager) 3
M Outlook 2007 "Connection Status..." shows 3 "Disconnected" entries of type "Directory" Using Outlook 18
T How to establish Soap Connection Outlook VBA and Custom Forms 5
S ClipMate clipboard connection Outlook Wishlist 1
M trouble connection to remote database BCM (Business Contact Manager) 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
Cathy Rhone Mail merge error message Using Outlook 0
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 4
