Need Help with Simple Code Correction
Coco
I'm very new to VB (like, several hours old!), and I have created a small code to run on an email that will add the email's original date stamp to the beginning of the subject line. The problem I am having (and I'm sure it is a simple code correction) is that it only works on one email at a time (the one selected). I need to be able to select a bunch of emails and have it run on all of them. Here is my code:
Sub Test()
Dim MItem As MailItem
On Error GoTo ExitPoint
For Each MItem In ActiveExplorer.Selection
MItem.Subject = MItem.CreationTime & " " & MItem.Subject
ExitPoint:
Anyone who can help I would be much appreciative!
Try something like this - i didn't test it and if it doesn't quite work, check the macro here - it 'does something' to selected items.
Sub Test()
Dim Selection As Selection
Dim obj As Object
For Each obj In Selection
Set MItem = obj
mitem.save
ExitPoint:
Coco
Thank you Diane,
I see the problem is that it is looking at currently viewed messages (as in, messages in the message pane). And only one message can be in the view pane at a time. If I simply highlight a message and am not viewing it in the pane, the code will not work at all. Since only one message could be possibly viewed at a time in the open pane, it still only works on one message at a time. I think I need a code that would work on all messages in a folder or something?
My code should work on the selection - it doesn't matter if it's being 'viewed'. just only need to select it. I'm working on an ediscovery project right now and can't double check the code until I'm finished with this though.
One thing you need to be aware of - 'created date' is generally going to be the date the message was either added to your mailbox or when it was downloaded. It's better to use Sent or Received date.
This worked here -
Public Sub ChangeSubject()
   Dim currentItem As Object
   Dim mItem As MailItem
   Dim obj As Object
           Set mItem = obj
           With mItem
               .Subject = "5: " & .Subject
               .Save
       Err.Clear
   Set currentExplorer = Nothing
   Set obj = Nothing
   Set Selection = Nothing
   Set currentItem = Nothing
ah... i see what we missed:
mitem.save before Next. Your code works with the save added too.
Coco
What command line would I use instead of CreationDate to pull either date sent/received?
Coco
Ok, macro up and running nicely, but I need to adjust. If the macro is inadvertently run a second time on the same email, the sent on date is inserted again, resulting in a subject line that reads: sentOn date + (sentOn date + original subject) .
Can I add some type of If/then statement that will detect if the subject already contains the sentOn date (the macro was already run on it) and skip that email?
Coco
that's why my sample used "5: " - it fits better after a few tests :)
Add this
Set mItem = obj
If Left(mItem.Subject, 6) <> Left(mItem.CreationTime, 6) Then
' more
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
D Need email verification for international emails, help? BCM (Business Contact Manager) 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
K Need help Publishing a new Task form! Outlook VBA and Custom Forms 1
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 4
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
