Outlook Macros for Appointments and Tasks
rhosyn18
So here's the situation. I create appointments for other people to go on. I create the appointment in a shared calendar and invite them to the appointment. I need outlook to set a task automatically (in their tasks) for 2 days after the appointment is scheduled to remind them to follow up. Is there a way to do this? I was thinking maybe a macro but I have little to no experience with VBA. Any help or ideas is greatly appreciated! I'm using Outlook 07 btw on an exchange server.
Macro can do it - I have a macro that creates a message when an appointment is added to a calendar, but the macro runs on the calendar owners machine. If you have write permission on their tasks, you could use a macro on your machine to create the task, but the macro needs tweaked to work with different calendars.
This macro would be tweaked to create a task instead, but it needs to run on everyone's machine:
Send an email when you add an appointment to your calendar - Slipstick Systems
it could also be changed to determine the active folder and use the correct tasks folder but I don't have the code handy to do that.
Diane Poremsky Using Arrays in Outlook macros Using Outlook 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
S Using Macros in the Outlook Calendar Using Outlook 2
A Outlook 2010 disabled macros Using Outlook 2
L Macros disabled in custom Outlook form Outlook VBA and Custom Forms 1
M macros of outlook 2007 Outlook VBA and Custom Forms 1
C Create macros in Outlook 2007 Outlook VBA and Custom Forms 5
S Need: Date handling in Outlook Macros, either information/documentation Outlook VBA and Custom Forms 1
N Copying outlook macros between pcs Outlook VBA and Custom Forms 1
D Macros Disabled in Outlook 2007 BCM (Business Contact Manager) 9
C Outlook macros have vanished Outlook VBA and Custom Forms 1
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
P How can I stop Outlook 365 duplicating the posts? Using Outlook 2
A force outlook to default to MY calendar Using Outlook 3
