VBA Macro to VBScript in a form- Help Please!
rhosyn18
Outlook 2007
Ok so here's what I want to do. I have a custom form that creates an appointment which I invite others to attend from a shared calendar. I want the form to also send an email that is delayed by 2 days from the start date of the appointment, to the person that is invited (the required attendee) that is set within the form. I have a macro in outlook where I can select the appointment in the calendar and then run the macro and it will send the email. But I want the form to do it all (so my coworkers don't have to go into the calendar and select the appointment then run the macro). Can this be done? I'll include the VBA for the macro below. Thanks!
Sub mail()
Dim obj As Object
Dim Sel As Outlook.Selection
Dim objAppt As Outlook.AppointmentItem
Dim objOutlook As Object
Dim objOutlookMsg As Object
Set Sel = Application.ActiveExplorer.Selection
Set objOutlook = CreateObject("Outlook.Application")
Set objOutlookMsg = objOutlook.CreateItem(0)
If Sel.Count Then  Set obj = Sel(1)
   If TypeOf obj Is Outlook.AppointmentItem Then
     Set objAppt = obj
     Set objTask1 = Application.CreateItem(olTaskItem)
With objOutlookMsg
  .To = objAppt.RequiredAttendees
  .Subject = "Business Banking Follow up reminder: " & objAppt.Location
  '.Body = "This is the body of message"
  .HTMLBody = "Test message! " & "Company: " & objAppt.Location & " " & objAppt.Start
   dteThen = objAppt.Start + 2
  .DeferredDeliveryTime = dteThen
  '.Attachments.Add ("c:\myFileToSend.txt")
  .Send
Set objOutlookMsg = Nothing
Set objOutlook = Nothing
To make it automatic, you need to use an application start macro and an itemadd macro.
See Send an email when you add an appointment to your calendar - Slipstick Systems for the code.
This code would add it to your outbox. I have not tested it, but you might be able to add it to the form - you need to use a script and would use a
Function Item_Send()
Vbscript is slightly different from VBA so the code will need tweaked a little.
If you wanted to use the script editor in a custom form (View code button), try this
Set MyApp = CreateObject("Outlook.Application")
Set MyItem = MyApp.CreateItem(0) 'olMailItem
With MyItem
  .To = Item.RequiredAttendees
  .Subject = "Business Banking Follow up reminder: " & Item.Location
  .Body = "Test message! " & Chr(13)  &  "Company: " & Item.Location &  Chr(13) & "Time: " & Item.Start
  .DeferredDeliveryTime =  Item.Start - 2
 ' .Send
   .Display
End Function
rhosyn18
Outlook 2007
Thanks for the quick response! I tried the script below in the script editor in my custom form. I don't receive any errors and the script looks sound to me, but when I use the form to set an appointment, no email is sent or placed in my outbox. Any ideas why?
With MyItem
 ' .Send
   .Display
End Function
Are you doing appointments or meeting requests? It works when you hit Send, not Save.
rhosyn18
Outlook 2007
I'm setting an appointment. So here's what I did. I went to design mode for the form, view script, and added that script to the editor and published the form again. Then I do my usual, (tools, choose a form..etc) I set the time, add the invitees, etc. when i click send, the appointment itself sends, but the email doesnt get added to my outbox. Am I missing something?
Does the email display? I have the code set to show the message, change display to send and it will go into the outbox.
rhosyn18
Outlook 2007
The email doesn't display, and I changed it to send instead of display and it still doesn't send. I can't find any reason as to why it isn't working.
Are you using the exact same script I posted?
Check Tools, Trust center - Email security - is script in shared folders enabled? if you use run now which designing the form, it should work but you may need that set when it's published.
rhosyn18
Outlook 2007
This was not enabled at the time, I enabled it and it still isn't putting an email in the outbox or sending the email at all. I used the exact script that you posted. For testing purposes I am publishing this form to my personal calendar and testing it before I publish it to the shared calendar. Would that affect it?
What addins are installed? I just had a guy tell me xobni prevents VBA from running. It worked when she disabled it, test the VBA, then re-enabled xobni.
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 8
