what is the best way to organize outlook contacts
gwardlaw
Outlook 2013 32 bit
I have a database of about 3000 contacts and I would like to organize them just once so I was wondering if it is better to assign categories to all of them or group them in contact groups or both or something else? In other words, when selecting groups for mail merge, what tools are best? Thanks for any advice.
My recommendation is to use Categories. If you want to create some contact groups, that is fine, but the main organizational method should be categories.
When you mail merge, you can start it in outlook - select just the contacts you want to include and start the merge.
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
A Organize by timezone in contact view Using Outlook 1
M Delegate for multiple people -need rules to organize! Using Outlook 0
