Updating Macro to OL2010/32bit
benjaminearle
I was forced to get a new OS (Win7/32) and new Outlook (2010 32bit) after my hard drive started threatening a catastrophic failure (click click beep beep beep).
I had a nifty macro in my old outlook that i re-installed in my new but it is not functioning completely.
For background, the only factory settings I have changed in OL are to attach an original when replying, replying to all or forwarding (to preserve attachments). I have enabled macros.
The macro should (did in Outlook 2003 and 2007):
1. Delete the original when replying, replying all, forwarding
2. Force a folder choice upon send
Item #2 is working, so I know the macro is at least trying to run. I assume some portion of the code just needs some 2010-style massaging. Any help would be greatly appreciated. This little tool has helped me keep my inbox under 100 items for years now. Very helpful since my inbox truncates, irretrievably at 30d age.
Macro:
' </DeleteOriginalWhenReply
Option Explicit
Private WithEvents ReplyButton As Office.CommandBarButton
Private WithEvents ForwardButton As Office.CommandBarButton
Private WithEvents ReplyAllButton As Office.CommandBarButton
Private WithEvents m_Inspectors As Outlook.Inspectors
Private m_Mail As Outlook.MailItem
Set ReplyButton = Application.ActiveExplorer.CommandBars.FindControl(, 354)
Set ForwardButton = Application.ActiveExplorer.CommandBars.FindControl(, 356)
Set ReplyAllButton = Application.ActiveExplorer.CommandBars.FindControl(, 355)
Set m_Inspectors = Application.Inspectors
Private Sub m_Inspectors_NewInspector(ByVal Inspector As Outlook.Inspector)
If Not m_Mail Is Nothing Then
m_Mail.Delete
Set m_Mail = Nothing
Private Sub ReplyButton_Click(ByVal Ctrl As Office.CommandBarButton, _
CancelDefault As Boolean _
If TypeOf Application.ActiveWindow Is Outlook.Explorer Then
Set m_Mail = Application.ActiveExplorer.Selection(1)
Set m_Mail = Application.ActiveInspector.CurrentItem
' </Assign Folder for Sent Messages
If TypeOf Item Is Outlook.MailItem Then
Cancel = Not SaveSentMail(Item)
Private Function SaveSentMail(Item As Outlook.MailItem) As Boolean
Dim F As Outlook.MAPIFolder
If Item.DeleteAfterSubmit = False Then
Set F = Application.Session.PickFolder
If Not F Is Nothing Then
Set Item.SaveSentMessageFolder = F
SaveSentMail = True
End Function
Many many thanks and I hope once repaired this code can be useful to others as well. Both of these actions seem like things that could be factory-integrated into Outlook to reduce inbox size.
-Ben
benjaminearle
It should work in 2010 too. Put in some breakpoints and see if it hits them.
It's working in 2013 - even with inline compose (reading pane compose) and a lot of stuff won't work with it.
I'll fall on my pride sword here - breakpoints? I didn't write that original macro in it's entirety. It was originally only used for "reply" and i added "reply-all" and "forward". So, it was largely copy/paste (i'm good at that).
I'll do some searching for the breakpoint bit but if I don't post an update, i'd sure like some help.
Also, I have it all in one Project - VbaProject.OTM - ThisOutlookSession (Code) under Project1 just like i did in 2007. Did I need to split it up?
-Ben
benjaminearle
OK, so i figured out the breakpoint thing (that's cool).
it appears to be skipping over these two lines:
m_Mail.Delete
they have little breakpoint buttons next to them but it hops from
to
And, the mail remains undeleted.
I goofed when I tested it - it was not working in Outlook 2013. I dropped a note to the guy who owns the site where I presume you got the macro from (he has one like it posted in his collection) - it looks like it should work but he'll know if there is something changed in outlook 2010 that would affect it. He's in Germany, so it might be tomorrow before I hear back.
Michael said its because command bars aren't supported in 2010 and he's going to update his page tomorrow. (I think what he means is the inspector cant identify the message because of changes to the command bar support.)
the original code VBOffice - Samples
benjaminearle
Thanks. I look forward to seeing the edited code.
Just heard from him - it looks like it won't be updated for 2010 due to the complexity that would be required to track the referenced item. Sorry.
P Updating Last Modified Date on ThisOutlookSession Macro Outlook VBA and Custom Forms 1
G Updating VbaProject.OTM on several users Outlook VBA and Custom Forms 3
T Office 2013 no longer updating automatically Using Outlook 2
G Mass Updating Contact form used Outlook VBA and Custom Forms 8
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
K Can VBA intervene when updating Internet Calendars? Outlook VBA and Custom Forms 5
S Task Update coming as email and not updating task Using Outlook 3
M search takes a loooong time since updating Using Outlook 8
T Shared calendar not updating Using Outlook 1
TotallyConfused Godaddy Microsoft exchange 2007 stopped updating Exchange Server Administration 1
S Updating the database based on received task Outlook VBA and Custom Forms 3
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
S Updating between Smartphone and PC Using Outlook 3
M Outlook 10 Inbox not updating Using Outlook 3
H Gmail not updating Outlook Home Using Outlook 17
Aalishaan Outlook 2010 Updating Inbox starts again Using Outlook 0
Alex Hall When updating shared calendar, it does not automatically update personal calendar Using Outlook 3
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
J Shared ICalendars are not updating in Outlook Using Outlook 2
A Updating Outlook Contact Phone Nos to international dialling codes Using Outlook 5
D Outlook 2010 - Pattern for updating task owner in generic mailbox Using Outlook 2
M Constantly updating address book Using Outlook 5
D Multiple Users Updating Custom Form At Same Time Using Outlook 1
D Updating a recurring meeting cuses a reminder to be sent for every occurence. Using Outlook 2
C Message Count not updating Using Outlook 2
H Cannot share calendar, global address book not updating Exchange Server Administration 1
C Updating many contacts at once? BCM (Business Contact Manager) 3
Z Updating .ics files in OUtlook 2010 Using Outlook 1
J Outlook changing from inbox/trash/sent, etc. is EXTREMELY slow since updating Windows a couple of days ago. Is there an issue with Outlook as to the Using Outlook 2
H Calendar not updating accepted appointments! Using Outlook 1
D Updating Accounts in Business Contact Manager Using Outlook 1
S Global address book, 1 users not updating Using Outlook 2
S Error updating public folder with free/busy information on virtual machine server. The error number Using Outlook 2
K Updating Contact Groups in Outlook 2010 Using Outlook 3
T Error when updating Internet Calendar Subscriptions Using Outlook 12
R Outlook 2003 - Exchange 2010 global address list not updating Using Outlook 3
A Updating contacts with new information BCM (Business Contact Manager) 1
S Outlook calendar tracking not updating meeting acceptances Using Outlook 5
M updating and saving contacts in Distribution List Outlook VBA and Custom Forms 2
M Updating appointments from Access 07 Outlook VBA and Custom Forms 4
T Appoinments Not Updating after Outlook 2007 SP2 Outlook VBA and Custom Forms 1
S Macro to extract email addresses of recipients in current drafted email and put into clipboard Outlook VBA and Custom Forms 1
