catalog Content Index failed-Unable to mount database.(hr=0x80004005,ec=-501)
ryk114
HI all
I faced this problem and i after long investigation i solve it as below ,,, first let me brief you about the issue .
we had power failure where all our data center went down (dirty shutdown) , our exchange environment as shown below :
2 x HUB/CAS servers
2 X MBX servers (in one DAG)
after power comes , all data bases have been mounted except one database ,, it failed on both DAGs , the status of this DB is as below :
MBX01 - Dismounted - Active True
MBX02 - Disconnected & resyncronizing , active False
the worst thing is here ,, the "catalog content Index is Failed" On both Copies , so no clean catalog index is available for this DB .
and once i tried to activate the passive copy its return an error message with the below error "the active DB is not mounted "
and if i tried to mount the active DB it gives error of "catalog content Index is Failed"
i've tried to repair the catalog contents index using the script "ResetSearchIndex.ps1" against the corrupted DB with no luck because both catalog on both DB copies is already corrupted .
after tow days of struggle , i solved the problem as below :
1. Stop the "Microsoft Exchange Search indexer Properties" service on EX01 .
2. Move all the logs (ALL logs ) to other location , Keep the DB folder path clean from any logs
3. mount the DB .
4. start the "Microsoft Exchange Search indexer Properties" service .
this what i did and it solves the problem and data base is mounted now ,,,
T Exchange 2010 DAG Failover Issue - Database Activation Fails because Content Index Catalog Failed Exchange Server Administration 2
W Failed to update Exchange search catalog during reseeding Exchange Server Administration 4
icacream content in this message could not be downloaded.... Using Outlook 2
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
GregS What controls content of Folder Pane? Using Outlook 1
O How to paste website content using a specific font and removing URLs Using Outlook 2
N Rename Subject Line with Email Content Outlook VBA and Custom Forms 3
N Paste content to Excel when .txt file (attachment) is opened Outlook VBA and Custom Forms 1
J Contacts 2016 Web page address content lost after updates Using Outlook 2
Randy Redekopp Outlook 2016 attachment content search Outlook VBA and Custom Forms 2
M How to duplicate content of one field in another field? Outlook VBA and Custom Forms 3
Z alter the timeout for how long outlook looks for a content-server on an HTML-email? Using Outlook 5
H Rule to move emails based on subject and content Outlook VBA and Custom Forms 1
R Can BCM monitor and select specific emails and use content info to update the client's record? BCM (Business Contact Manager) 1
J Duplicate Attachments in Content.Outlook Using Outlook 4
D Create Exchange Rule for everyone that highlights an email based on content of subject Exchange Server Administration 1
O Copy email content and paste into new Word Document using a different font Using Outlook 1
G Content Lost From Draft, Returns Upon Refocus? Using Outlook 0
G Outlook Intermittent Issue with Drafts not Displaying Entire Content Using Outlook 4
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
R Content occcasionally deleted email message is dragged to shared folder Exchange Server Administration 1
dolke Strange Outlook behavior when receiving emails. More info in the content... Using Outlook 7
R Issue in Mail content on my outlook Using Outlook 1
C Create a rule to only check new content in email - disregard original content Using Outlook 3
M IMAP header/content mismatch! Using Outlook 4
S Outlook 2003 SP3: Content of appointments for some users not visible in group schedule view. Using Outlook 2
S DAG Content Index failed Exchange Server Administration 2
O Email content/text is deleted when I receive an email w/ a PDF attachment Using Outlook 1
H Outlook 2007 slow folder content display after installing kb2412171 Using Outlook 33
E Outlook 2010 - email windows not showing any content Using Outlook 1
I Outlook email content display issue Using Outlook 3
J How preview the content of a calendar event ? Using Outlook 4
B Public Folder content replication from 2003 to 2010 Exchange Server Administration 2
S Event ID 9877 - Content Indexing function 'CISearch::EcGetRowsetAndAccessor' received an unusual and Exchange Server Administration 1
E Inbox emails appear for a brief instant and then Inbox shows no content Using Outlook 2
M Missing message content in Outlook 2010. Using Outlook 4
K Custom Content Control or field to pull specific Outlook Address Book information into Word doc? Using Outlook 1
S Windows 7 search is not finding content in Outlook 2007 PST files__ Using Outlook 1
M Outlook 2007 Calendar Tri Fold content Using Outlook 2
N Re: Exchange 2010 Content Index Exchange Server Administration 6
H outlook 2010: random font changes, missing email content, source html displayed in-line with text Using Outlook 3
J Exchange 2010 Blank Message Content in HTML mails Exchange Server Administration 16
T Can not change email body content on Outlook 2010 Outlook VBA and Custom Forms 2
