Macro Shortcuts
LMS
Outlook 2007
As to all the macros I have per the past wonderful support, and yes I can create a macro shortcut on the toolbar as well.......so the question is:
Is there a way to create a keyboard shortcut to a macro. So if have a macro that creates an email to the contact I identify, it would be great to, for example, just click Alt+d, and it runs the macro.
Can I set this up for all my macros or some of them?
Thanks so much as usual.
In 2007, yes, you can create shortcuts in the old toolbars - when you customize the button name, add a leading _ for the desired shortcut. If you assign a shortcut that is already assigned, you'll need to press the letter twice.
The QAT has shortcuts assigned automatically.
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
N Macro for attachment saved and combine Outlook VBA and Custom Forms 1
C Search with Google Macro? Outlook VBA and Custom Forms 4
