can't view email body please help!
ippokun
When I am reviewing some historic emails, I can see the following details in my inbox, however when I then double click on the emails to display the details I get nothin:confused:
ippokun
the email is at archive folder, and haven't tested yet using safe mode.
do you mean safe mode in start up or in outlook safe mode?
Outlook Safe mode. I'm wondering if security software is blocking it.
It's also possible the archive process was messed up and the details you see is all there is. How was the archive created? What is the source of the details you see when you look in your inbox?
ippokun
please do take note that this emails came from lotus to outlook. our users are migrated from lotus to outlook. thanks!
Oh. I wonder if the messages were corrupted during the transfer.
Are you using lotus on the back end and Outlook on the front end or did you migrate away from lotus completely?
ippokun
we migrated all they way, we don't have access to lotus notes anymore, we are now using the outlook of office 365
T How can we view Blocked email addresses Using Outlook 6
V Macro to view Junk Email folder Using Outlook 4
P How can I view a german email in outlook 2002? Outlook VBA and Custom Forms 1
P View EMail from MS Access Database Outlook VBA and Custom Forms 2
Commodore MHT files (from "View in browser") Using Outlook 7
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Using Outlook 1
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
B outlook view control Outlook VBA and Custom Forms 0
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
