VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form
Arimis
Our anti-spam provider wants all false-negatives forwarded such that they can be run through their heuristic and linguistic algorithms to improve their capture rate. I was able to cobble together a script (works) and create a toolbar click (works) from various snippets of code. The problem is that the forward contains the default signature for forwards / replies (which they don't want to see). I've beaten my head against the wall trying to have the script to use a custom form (without a signature) to no avail. The signature is always there. Here's a copy of the script I'm using.
Sub SPAM()
Set objItem = GetCurrentItem()
Set objMail = objItem.Forward
objMail.To = "spam@mx25.net"
objMail.Display
Set objItem = Nothing
Set objMail = Nothing
Set objApp = Application
Case "Explorer"
Set GetCurrentItem = _
objApp.ActiveExplorer.Selection.Item(1)
Case "Inspector"
objApp.ActiveInspector.CurrentItem
Case Else
End Function
If someone could advise as how to either use a "blank" form for the submission or how to strip the signature, that would be blessing.
Not tested... but try objMail.body =""
then objMail.body = objitem.body
Or something like that. It you need to senders, address or date, you can create a header block :
Dim strHeader As String
strHeader = "------------------" & objItem.SenderName & vbCrLf & objItem.SenderEmailAddress & vbCrLf & vbCrLf
objMail.Body = strHeader & objItem.Body
Do they only need the body or also the message header?
Arimis
Greetings All (and especially Diane Poremsky)
If your anti-spam provider would like exemplars of false-negatives and you want to automate the process at much as possible, the following script works flawlessly in an Outlook 2007 environment. It grabs the focused false-positive and just sends it off to the eval algorithms of your anti-spam provider. The only thing you have to change is the objMail.To reference. Here's the script.
Sub SPAM()
Set objitem = GetCurrentItem()
Set objMail = objitem.Forward
objMail.Body = ""
objMail.Body = objitem.Body
objMail.To = "your anti-spam provider"
objMail.Display
Set objitem = Nothing
Case "Explorer"
Case "Inspector"
Case Else
End Function
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
F VBA script to highlight specific words Outlook VBA and Custom Forms 1
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
M VBA script to allow mail merges of distribution groups? Using Outlook 7
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
L Limit VBA Script to one Outlook account Using Outlook 1
