Outlook 2010, reading pane, global settting for fields?
Flashfox
I wonder if it is possible to apply a global setting so that Outlook shows the fields I want in the preview pane?
For example, by default, Outlook's preview pane doesn't show the "to" field. I need to add this in each folder I have. As my folder structure is complex, it requires me to add this field in all folders, one at a time. I was hoping that I could apply it to the "top folder" and tell Outlook to apply to all sub-folders. Unfortunately, I haven't found a way to do this.
Is what I am asking for even possible in Outlook 2010?
J Outlook 2010 reading pane option - want to permanently adjust the zoom setting. Using Outlook 13
A Outlook 2010 keeps closing and restarting when reading messages Using Outlook 12
S Outlook 2010 reading pane not clearing Using Outlook 3
