Editing tasks: highlight & copy/cut NOT working in Calendar entries
MC.Raymond
Outlook 2013 64 bit
Hello
Surprised to find that a problem that developed recently in my old Outlook 2007 is a problem in the new Outlook 2013, on a new computer. Inside a calendar appointment entry, if I paste text in the body of the entry, I cannot highlight in order to copy/cut text. For example, I just booked a flight and copied the flight details off of the website and pasted these into the body of a new appointment in calendar. In the past (before the problem started in Outlook 2007) I could then highlight part of the text and copy this into the subject and location fields of the appointment. This feature vanished a few months ago in Outlook 2007 and was one of the reasons for upgrading to Outlook 2013. Now I find that basic editing tasks (highlighting, copy/cut) are not possible in the body of an appointment in Outlook 2013.
Is this the new normal for appointments? Or a glitch? If the later, how do I correct the problem?
Walter:confused:
MC.Raymond
Outlook 2013 64 bit
Yes. iCloud ... Is switching to SkyDrive a solution. Would this be very complicated -- can SkyDrive sync calendars & contacts on iPhone & iPad?
No skydrive won't work. You can use the arrow keys to hightlight and select - use Ctrl+C to copy if necessary. It's possible the next iCloud update will fix it.
S Editing Tasks in Outlook 2016 Using Outlook 6
N editing drafts - won't let me save Using Outlook 12
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
J Forward Message after editing attachments and include edited attachments Using Outlook 5
Diane Poremsky Editing the Subject Line in Outlook Using Outlook 0
Q Editing an outlook. Template file (Otk) Using Outlook 1
mrje1 Note Field (Any way to do incell editing) Using Outlook 7
D Conflict warning while editing Exchange Server Administration 0
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
Commodore Editing contacts and adding photos Using Outlook 4
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
L Editing auto reply email from a shared mailbox? Exchange Server Administration 7
K Editing a .PRF file for new users after deploying Outlook 2010 with MSP Using Outlook 5
A outlook printing assistant Help editing template Using Outlook 3
kburrows Outlook 2013 - Inline Editing of Contacts Using Outlook 4
B Editing Calendar Categories Using Outlook 3
C Outlook editing won't select just one word Using Outlook 1
G Editing the Read Receipt Using Outlook 1
J Outlook 2010 Editing Forms Using Outlook 3
J Joint Calendar Sharing - Editing Using Outlook 1
F add new panel to email editing window Outlook VBA and Custom Forms 2
T Editing Mailing List BCM (Business Contact Manager) 1
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 6
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 5
K Outlook tasks formatting Using Outlook 4
P Searching tasks that are archived Using Outlook 4
