Auto BCC VBA macro: how to add exceptions?
it would go at the top of the macro. if you need to do this for a multiple names, i would use categories or a keyword in the subject.
if item.categories = "no bcc" then
exit sub
else
'bcc code
end if
everything before the Private is the problem. the code goes in the macro, not before.
Private Sub Application_ItemSend(ByVal Item As Object, _
Cancel As Boolean)
Dim objRecip As Recipient
Dim strMsg As String
Dim res As Integer
Dim strBcc As String
exit sub
else
' #### USER OPTIONS ####
' address for Bcc -- must be SMTP address
' or resolvable to a name in the address book
strBcc = "address@domain.com"
Set objRecip = Item.Recipients.Add(strBcc)
objRecip.Type = olBCC
If Not objRecip.Resolve Then
strMsg = "Could not resolve the Bcc recipient. " & _
"Do you want to send the message?"
res = MsgBox(strMsg, vbYesNo + vbDefaultButton1, _
"Could Not Resolve Bcc")
If res = vbNo Then
Cancel = True
end if
Set objRecip = Nothing
You'd probably want to check for a category, either using if item.categories <> "bcc" then
or run the code if the category exists
if item.categories = "bcc" then
' bcc code
else
end if
boppy2010
Unfortunately this is my first exposure to VBA plus I have a cold so my head is not working right. I've moved that text but still getting an error, albeit it in a different place:
http://imm.io/19xQ9
I've pasted the code here in the hopes that you may take pity on my befuddled state and put it in the right order ...
Dim res As Integer
' address for Bcc -- must be SMTP address or resolvable
' to a name in the address book
strBcc = "1kawa9@mails.zohocrm.com"
"Do you want still to send the message?"
"Could Not Resolve Bcc Recipient")
If res = vbNo Then
Cancel = True
Dim res As Integer
If Item.Categories = "personal" Then
'bcc code
end if Private Sub Application_ItemSend(ByVal Item As Object, Cancel As Boolean)
If res = vbNo Then
Cancel = True
I think its still the red line - in the sample above, you have
it should be
end if
end sub
It looks like you have 2 or 3 different copies of the macro or bits of the macro. You only need one macro, if you want to use different bcc addresses, you need to use if statements. This sample bcc's different addresses based on the category you assigned to the item.
                                Cancel As Boolean)
   Dim res As Integer
   If Item.Categories = "Personal" Then
ElseIf Item.Categories = "Important" Then
     strBcc = "new@address.com"
       If res = vbNo Then
           Cancel = True
boppy2010
So in this section:
> .. I presume the first address@domain is my Zoho CRM address but what goes in "new@address.com"?
But then it doesn't seem to be using the "personal" category to add exceptions to the bcc.
the second address is if you want to BCC to other addresses. if you only use one bcc, use
If you want to BCC everything except items marked personal (or whatever category you decide),
use If Item.Categories <> "Personal" Then
and add a category when you don't want to BCC a message.
boppy2010
Well this is what I have now and it's not bbc-ing:
Cancel As Boolean)
Dim res As Integer
If res = vbNo Then
Cancel = True
Did you set a category on the message you were sending?
Is the macro in ThisOutlookSession?
Is macro security set to low?
boppy2010
No I want to BCC ALL addresses except those marked personal. it would be too complicated to make a category for every other email I send.
Right, you want the default to the most used.
This should be
That will tell it to set the bcc address and continue if the category is not personal or is not present. If its found, the macro exits.
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 14
