Desperate for Help with Outlook custom form
We have developed a custom outlook form based on a
standard meeting invite. The issue is when user sends this custom form to the
invitee they are not able to see the custom form and it reverts to a standard
out of box meeting invite. I have already tried a whole bunch of things and now
running out of options. The form is published in Org Form Library where every user have access to.
The test accounts, live accounts, and the public folder for outlook form library are on Exchange 2010.
The forms are not using caching as it have been disabled already while development. So it always look for a fresh copy of the form.
I created my another custom form with just one control and tested, but the result was the same, it doesn’t show content at the receiving end. Sometime it shows in Inbox item but when you open in calendar item the custom tab is gone.
I added some code to check for each item in the calendar if it’s using the right Message Class and it also didn’t yield any result. I don't have much of time and any quick reply will be very very helpful. thanks in advance
I also tried with Send with Form Definition Option under proerpties under design this form under developer tab but no result. it still doesn't show up at the receiver end. anything on google about the custom form not showing up at the receiver end has been tried but nothing seems to work. please help
D Desperate hours BCM (Business Contact Manager) 1
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
A newb outlook macro help Outlook VBA and Custom Forms 1
X Help with custom form which is very similar to Tasks Outlook VBA and Custom Forms 6
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
L Looking for help - want to try an alternative to Outlook? Outlook Wishlist 0
M Help! Can't set up IMAP for gmail Using Outlook 2
