Outlook 2010 won't save 'current view' with reading pane at 'bottom'
bergonzi237
Hi World! I have Outlook 2010 (32bit) and have been using it flawlessly until yesterday when I couldn't even open it! Managed to overcome that problem by insert disc/ repair, and created new profiles, linking them to previous outlook pst. files. Send/receive all working fine! Now, I select reading pane under 'view' to 'bottom' coz that's where I like to see stuff, but no matter what I seem to do, when I close Outlook and re-open it defaults to the reading pane being at the side again. Frustrated , or what? Any ideas please?
bergonzi237
When you close Outlook, check Task Manager and see if it's still listed on the Processes tab a few seconds after closing. If so, its not closing correctly and the change is not being saved.
Hi Diane, Thanks for your reply. I have checked this and when Outlook closes there is nothing listed in the processes tab, it closes straight away.
I'm assuming outlook is not stuck in Safe mode - so try closing it and restarting using the /cleanviews switch. If you have any custom views it will wipe them out though.
Try closing Outlook and restarting with the /cleanviews switch -
In the Start menu, search field (or use Windows key+R to open the Run command), type or paste
outlook.exe /cleanviews
and press enter. Note, there is a space between outlook.exe and the /.
For more info, see
http://www.outlook-tips.net/beginner-user/reset-the-view-in-outlook/
bergonzi237
Hi Diane, Outlook not in Safe mode. Tried as you suggested, no joy. Best I can get is to select reading pane 'off'. It keeps that when I open up Outlook. It also saves and opens up with 'right' selected. Just when I select 'bottom', it fails to re-open in 'bottom' mode!!!:rolleyes:
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
S Outlook 2010 won't send on Windows 8 Using Outlook 2
C Outlook 2010 Address Book, won't stay selected Using Outlook 5
J Email won't send Automatically in Outlook 2010 Using Outlook 3
B Outlook 2010 won't preview Office attachments Using Outlook 3
B Outlook 2010 asking for password constantly, won't accept correct one Using Outlook 5
C Outlook 2010 won't use a view other than maximized Using Outlook 1
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
D Outlook 2010 won't launch after installin Microsoft office 2010 service pack 1 Using Outlook 1
J Outlook 2010 won't start in Win 7 Using Outlook 4
