Restricting access to certain features for specific users
JackAustin
Hello Team,
I am currently implementing BCM across a medium sized business and was wondering if there was a way of restricting access to certain features. This specifically relates to the mass communication feature.
Many thanks
Jack
jasper90
Outlook 2013 64 bit
Is there anyway to prevent them from exporting the contacts?
F Re: Restricting Database Access Using RBAC Exchange Server Administration 4
B Re: Restricting Database Access Using RBAC Exchange Server Administration 3
Jim H. Restricting session mail with ConversationID Using Outlook 6
S rule, automatic replies, restricting them to within the company Using Outlook 1
K Restricting Outgoing Email Using Outlook 1
Jennifer Murphy Grant R/W (update) access to a friend Using Outlook 3
O The page that you are trying to access cannot be loaded. Using Outlook 0
T Render Outlook emails in MS access as they appear in Outlook Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
GregS Can't access archive file Using Outlook 5
R How can I access my emails from corrupt offline files of MS Outlook ? Using Outlook 1
F Outlook 2016 bulk email from access Outlook VBA and Custom Forms 3
J Programmatic access grayed out Using Outlook 10
Diane Poremsky Synchronize Quick Access Toolbar and Ribbons? New Slipstick.com Articles 0
T Cannot access outlook.com accounts in Outlook 2016 Using Outlook 1
B Can't expose sender email address when linking outlook to access Using Outlook 3
Diane Poremsky Change Outlook's Programmatic Access Options New Slipstick.com Articles 0
S how to access the properties of a contact given distlist.member object Outlook VBA and Custom Forms 1
C Merging Word and Access into Outlook Using Outlook 4
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
B No permission to access Outlook.pst file Using Outlook 1
M Cannot access the Form Editor BCM (Business Contact Manager) 1
R The changing way to access information in Office 365 New Slipstick.com Articles 0
iwshim Skype tool bar in quick access ribon Using Outlook 1
JorgeDario restrict access to a certain folder with vba Outlook VBA and Custom Forms 3
U Cannot access fields at bottom of Outlook 2013 Contact Rec. Using Outlook 1
S Can't move the items. The item could not be moved. It was either already moved or deleted, or access Using Outlook 3
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
R Convert Access table to pst Using Outlook 1
