Printing Issues in Outlook 2007
P-Lo
I have recently installed an HP OfficeJet Pro X476dw and am now unable to print anything within Outlook 2007 (printing in everything else is fine). It won't let me change and save the default to Tray 2. I can go in and change it in several locations and click OK, but when I go to print, it defaults back to Tray 1. I've even tried to create a new print styles and that doesn't work. I went around and around with HP Support and they say that it is an Outlook 2007 problem. I've "repaired" my Office 2007 installation, but that didn't fix it. Do you have any suggestions?
Delete outlprnt file.. but if the problem is that outlook won't let you use non-default settings, that is normal. It should use them if you go into the print menu to print but if you use quick print, it will always use the default printer settings - and this is default as in the printer says its the default.
P Printing, pasting & deleting issues Using Outlook 4
J Issues printing HTML emails - Contacting server for information Using Outlook 1
A How to use calender printing? Using Outlook 1
M Printing Appointments Using Outlook 1
M Calendar daily Appointments and printing Using Outlook 0
T Printing from Outlook is now defaulting to "Shrink to Fit"! Using Outlook 5
snissen Printing foreign language messages Using Outlook 1
L printing contacts Using Outlook 1
A How to get rid of Contacts field when printing emails? Using Outlook 0
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
D Printing Contacts Using Outlook 2
C Printing tasks with multiple categories Using Outlook 5
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
S macro for opening attachments and printing Using Outlook 1
J Printing Mulitple Calendars Outlook VBA and Custom Forms 1
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
G booklet printing in outlook 2007 Using Outlook 1
W Meeting printing background fields Using Outlook 0
K calendar printing Using Outlook 1
M Outlook 2013 is printing headers only Using Outlook 4
S So Disappointed in Calendar Printing Assistant!! Using Outlook 2
D Printing Attachments Automatically in Outlook 2010 Using Outlook 1
F Printing all day events only Using Outlook 3
J outlook printing Using Outlook 2
J Printing Calendar in Outlook 2013 Using Outlook 0
C Printing Outlook Form Controls via Word Using Outlook 11
E Printing Using Outlook 1
C Custom .oft / Printing Issue(s) Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
E Outlook 2010 network printing problems Using Outlook 4
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
I Printing Using Outlook 0
E Monthly Style Calendar Printing Using Outlook 6
S How to remove tracking from printing - outlook 2010 Using Outlook 4
P Printing calendar (work week) with numerous (i.e. >7) all day events... Using Outlook 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Using Outlook 2
E Adding Start and End Time to Daily View in Calendar Printing assistant Using Outlook 1
M Outlook 2010 task line printing Using Outlook 1
S Printing Selected Date Range in Monthly Style Using Outlook 1
S Does Printing Assistant Work with Windows 8 and Office 10? Using Outlook 1
A outlook printing assistant Help editing template Using Outlook 3
S Printing Category Key on Calendar Using Outlook 1
P Printing Issue on Calendar Printing Assistant Using Outlook 0
W Calendar Printing with Outlook 2010 (64 bit) Using Outlook 1
R printing fields in addresses Using Outlook 1
