VBA for Dialog Box when sending Email
philcaz
I am looking for help and maybe some VBA that will do the following in Microsoft Outlook 2010:
Prompt me every time that I send an email, asking me if i want to flag this email for follow up
I am tried for days looking for some type of solution and am not getting anywhere. Can someone please help me or point me in the right direction?
All help is much appreciated.
sperrysoftware.com has a follow up addin that might meet your needs, but if you want to got free and cheap, you could use VBA.
This will ask you as the mail hits the sent folder:
Option Explicit
Private WithEvents olSentItems As Items
Dim objNS As NameSpace
Set objNS = Application.Session
' instantiate objects declared WithEvents
Set olSentItems = objNS.GetDefaultFolder(olFolderSentMail).Items
Set objNS = Nothing
Private Sub olSentItems_ItemAdd(ByVal Item As Object)
Dim prompt As String
prompt$ = "Do you want to flag this message for followup?"
If MsgBox(prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Check Address") = vbYes Then
With Item
.MarkAsTask olMarkThisWeek
' sets a specific due date
.TaskDueDate = Now + 3
.FlagRequest = "Followup "
.ReminderSet = True
.ReminderTime = Now + 2
.save
philcaz
Thank you so much for your help, here is my current code but it isn't prompting for the flag, any ideas? Also note I have a current script on top for BCC'ing my gmail address on all sent items, but they shouldn't be affecting each other.
Here is my current code, any help is appreciated:
Dim objRecip As Recipient
Dim strMsg As String
Dim res As Integer
Dim strBcc As String
' #### USER OPTIONS ####
' address for Bcc -- must be SMTP address or resolvable
' to a name in the address book
strBcc = "fakeemail@gmail.com"
Set objRecip = Item.Recipients.Add(strBcc)
objRecip.Type = olBCC
If Not objRecip.Resolve Then
strMsg = "Could not resolve the Bcc recipient. " & _
"Do you want still to send the message?"
res = MsgBox(strMsg, vbYesNo + vbDefaultButton1, _
"Could Not Resolve Bcc Recipient")
If res = vbNo Then
Cancel = True
Set objRecip = Nothing
Option Explicit
Set objNS = Nothing
If MsgBox(prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Add flag?") = vbYes Then
With Item
' sets a due date in 7 days
.TaskDueDate = Now + 7
.ReminderSet = True
.ReminderTime = Now + 6
.Save
BCC shouldn't affect it - it runs as the message is sent, the itemadd macro runs after its added ot the sent folder.
It's an application startup macro - did you click in the application_startup macro and press run?
philcaz
Here is the error I am getting when I click run.
I notice you have 2 End Sub in the screenshot- that is not quite the right error message for two end subs, but see if removing one fixes it.
philcaz
Here it is again...same result - see the highlighted text is blue? The program is highlighting that when the error comes up so it has something to do with that.
That's the missing sub to the extra end sub. :)
I missed the mixup when i looked at your code earlier and didn't have time to paste it into the VBA editor or i would have picked up on it sooner -
This
Option Explicit
<snip>
should be
Option Explicit
paste this code at the top of ThisOutlookSession -
Option Explicit
Dim res As Integer
If res = vbNo Then
Cancel = True
Set objNS = Nothing
With Item
.ReminderSet = True
.Save
P How to Open File Selector dialog in VBA Outlook VBA and Custom Forms 4
B how/what dialog boxes can I display from VBA code Outlook VBA and Custom Forms 1
