Is there a way to prompt a user before deleting an item?
chockomonkey
Currently if the Del key is pressed while an account is selected, it goes right to the Deleted Items folder without prompting the user if that's their intended action.
Is there a way to change this?
xiaodongchen
Outlook 2013 32 bit
I asked about this because Windows 8 computers using a Microsoft Account logon can't connect to a shared db.
You can use windows accounts... as long as all use the same account. Obviously not good for sharing with coworkers but works well to share with your own multiple computers. oh, and the db needs to be on one of the computers - you can't use an external sql server.
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
Q sending mail when Otlook in 'always prompt for user name and passw Outlook VBA and Custom Forms 4
R Make Enter Network Password Prompt Go Away Automatically Using Outlook 0
K VBA to prompt and send a CC Outlook VBA and Custom Forms 6
K VBA - Prompt for reminder date time Outlook VBA and Custom Forms 7
P Constant Username Password Prompt Using Outlook 2
A Prompt on exit to empty deleted items folder "for all accounts" does not work? Using Outlook 6
S Prompt to add for text to existing subject line before sending. Using Outlook 9
S Trying to have a prompt to ask for text to be added to subject before sending. Using Outlook 3
N Prompt for password when sending an email Exchange Server Administration 1
O How to turn off the prompt to permanently delete messages upon exiting? Using Outlook 2
M Email Prompt Outlook VBA and Custom Forms 1
T Prompt for email account Outlook VBA and Custom Forms 1
P Outlook security prompt after installing Add-in Outlook VBA and Custom Forms 3
Q Otlk 2007 does not block when in "always prompt for..." mode Outlook VBA and Custom Forms 2
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
icacream Enter your user name and password for the following server. Using Outlook 4
R Creating a user defined function Outlook VBA and Custom Forms 3
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
G <mailto:user@domain.com<mailto:user@domain.com<mailto:user@domain.com>>> Using Outlook 5
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
A Created a new user account and the local account cannot see email Using Outlook 3
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
M other user's mailbox won't open, forms disappeared Using Outlook 42
N Select a folder in a user account Outlook VBA and Custom Forms 2
S Outlook User defined date field (UDF) not syncing Using Outlook 2
