Imported Tasks - Pop Up does not work
David Randle
I have imported a number of tasks into Outlook 2010 (exchange) from Excel 2010.
All the fields populate correctly and the reminder box is checked as it should be however the reminder pop-up does not activate at the deignated time.
I exported the tasks list back to excel and the reminder value is showing as true.
Strangely hwoever, the reminder does pop-up on my Blackberry.
Would appreciate some assistance with this.
David Randle
Are reminders enabled in Outlook? Do they work for appointments or tasks you create in Outlook? Did you try restarting Outlook using the /cleanreminders switch? That rebuilds the reminders folder.
Thanks for your response. Yes, reminders are enabled and they do work for tasks created directly in Outlook. In fact, if I import a reminder and turn it off and back on again before the alarm time, it will work.
I hadn't tried the cleanreminders swich before but have now done so and it did not solve the problem.
I'll test it when I get back in my office, I only have my iPad with me.
B All imported tasks appear in to-do list Using Outlook 3
J Moving Imported folder Using Outlook 2
E Imported Contact Issues Using Outlook 11
R I have imported a .pst file into my outlook and I cannot locate it. It seems to be in my main Inbox Using Outlook 1
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
A Contacts missing in imported mails Using Outlook 1
cimbian Filtering exclusive imported contacts Using Outlook 3
U Imported contacts to appear in Autocomplete Using Outlook 1
G How many contacts can be imported into BCM BCM (Business Contact Manager) 1
F Macro to update imported contacts Outlook VBA and Custom Forms 6
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 6
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 5
K Outlook tasks formatting Using Outlook 4
P Searching tasks that are archived Using Outlook 4
T Extract Data From Outlook Tasks Using Outlook 0
I To-do bar (tasks) Using Outlook 1
O Tasks - Is there a postponed date column? Using Outlook 7
O Outlook 365 - Tasks are not synchronizing? Using Outlook 7
F some tasks are disappearing Using Outlook 4
F How to show assigned tasks under certain mailbox? Using Outlook 4
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
M tasks in todo list appearing twice Using Outlook 3
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
F Finding Meetings/Tasks in a date range Using Outlook 1
