Voting and auto reply
tabbakh
I have created a dedicated email account to be used for voting
I do not want any body to send an email to this email, only to respond by voting. so I created a rule to make the server auto-reply for any email to ask the sender to use the voting.
the server responded to everyone included the people who voted only
how can I overcome this?
regards,
tabbakh
Autoresponses are an all or nothing thing (and only once per session). You'd need to use a server side rule (assuming you can log into the mailbox) but none of the rules i tried are server side. :(
Thank you for your response, I did not use an auto reply, I created a rule "have server reply using a specific message". This replied to everybody (including who only voted)
it was really embarrassing, and also messed up with the tracking
I am thinking of putting a condition using "with a size in a specific range", Votes are only 1 KB in size, I guess if I use a bigger size (10 KB or so), it will only respond to messages not votes.
Do you think this would work? and will not affect the tracking?:confused::confused::confused:
Best regards,
In theory it should work. You'll need to test it to know for sure.
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
C Voting Issue with Shared Inbox Using Outlook 1
R How can I retain embedded object with voting button reply? Using Outlook 5
F Stationery with Voting buttons Using Outlook 9
P VBA create mail with attachment and voting buttons Using Outlook 6
H Issue with Custom Voting options Using Outlook 3
S Voting Buttons are Not Tracking Using Outlook 1
P Voting buttons not showing Outlook VBA and Custom Forms 1
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
S HELP: Add logic to what Voting buttons do Outlook VBA and Custom Forms 1
