Outlook Appointments - Setting default text in message body
iandv
Outlook 2007
In Outlook 2007/2010 is there a way to pre populate the message box (just under the end time box) when creating a new outlook appointment?
Many Thanks
You can use VBA - that is .body field. If you want every single appt you create to have the same information, you can use a custom form.
Paste this in the VBA editor and run it - only appt created via the macro will have something in the body field.
Sub newappt()
Dim cAppt As AppointmentItem
Set cAppt = Application.CreateItem(olAppointmentItem)
With cAppt
   .Subject = "New: "
   .Start = Now() + 0.125 'fraction of a day
   .Duration = 130 'minutes
   .Location = "Somewhere, over the rainbow"
   .Body = "Making a new appt!"
   .Display
iandv
Outlook 2007
Will this work with macros turned off? As on our Intranet I think macros are off by default.
And by including this vb code how could you replicate this across certain users in the domain for this shared calendar?
No, it won't work if you can't use macros. Sorry.
You'd need to add it to each person's Outlook.
For a shared calendar, you could use a custom form published to the shared calendar folder and set as the default form for that folder. It should work for all users.
B Outlook Calendar/setting appointments Using Outlook 1
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
M warning for too many appointments on a same day in Outlook Using Outlook 1
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
A Outlook.com changing appointments Using Outlook 8
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
N Outlook Shared appointments automatically to Private Calendar Using Outlook 1
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
C Appointments from Excel to Outlook Using Outlook 3
N Outlook 2010 Archived Appointments Missing Using Outlook 5
W Outlook 2010 - Displaying Private Appointments In Shared Calendars Using Outlook 1
T Synchronize outlook appointments through web application. Using Outlook 1
R Outlook Macros for Appointments and Tasks Using Outlook 1
D Priting only Recurring Appointments in Outlook Calendar 2010 Using Outlook 1
G Can't see all my appointments on Outlook calendar Using Outlook 2
M Change Meetings to Appointments in Outlook 2003 Using Outlook 6
M Outlook 2010 - linking appointments to contact activities Outlook Wishlist 9
M Outlook Calendar Monthly View Missing Appointments Using Outlook 3
B Outlook 2010 People Pane doesn't display appointments Using Outlook 2
F Outlook 2007 - recurring appointments shifted by one day Using Outlook 4
M Outlook - Search Criteria for Overdue Appointments Using Outlook 3
F Outlook Calendar is "dropping past appointments" Using Outlook 1
S Outlook 2003 SP3: Content of appointments for some users not visible in group schedule view. Using Outlook 2
R Error message "Cannot save free/busy information" when changing or deleting appointments in Outlook. Using Outlook 4
A Outlook 2007 won't show appointments/meetings in calendar on actual date, only on date appt/mtg made Using Outlook 1
J Cannot see calendar appointments for Outlook 2007 Using Outlook 1
O Outlook calendar view changes from 'Day/View/Month' to 'All Appointments' automatically Using Outlook 2
C Appointments Template - Outlook 2010 Using Outlook 1
C Outlook Taskbar Shows all Appointments as Recurring Using Outlook 2
I Outlook 2010: Appointments not visible in shared calendar if free/busy is set to Free. Using Outlook 2
M Calendar Appointments to Lotus Notes User via Outlook 2007 Fails Using Outlook 2
M Calendar Appointments to Lotus Notes User via Outlook 2007 Fails Using Outlook 1
S Unable to add new appointments to Outlook Using Outlook 2
D Change 'modified' date for Outlook 2007 appointments Using Outlook 3
M Outlook 2010, journal, appointments, other items do show up in contact activities Using Outlook 1
K Upcoming Appointments - How Far in Advance does Outlook show? Using Outlook 1
K With Outlook 2010 appointments not visable on the Month view but their day and week can be seen. Using Outlook 2
A Recurring Appointments in Outlook 2010 Using Outlook 1
D Outlook 2007 reinstalled, but appointments don't show in To Do bar for new calendar that was created Using Outlook 1
S Shared calendar in Outlook 2010 shows no appointments Using Outlook 7
D Exchange 2007 appointments rendering issue in Outlook 2003 Exchange Server Administration 3
C Outlook Categories for appointments Using Outlook 2
R outlook 2010 calendar appointments Using Outlook 2
I Outlook 2003 shows html code when To: field is empty Using Outlook 5
