How do I keep my old PST file as default
shakeitsgreat
I recently added an exchange server account to my outlook. Outlook selected this account as my default, and now all of my calendars and appointments are not working properly. I have 4 accounts assigned to my outlook and would like to continue using my current PST file, however, I can no longer keep my PST file as the default. I can make any other file default (including the OST file), but not my original PST. I believe this is because my file is from an older version of Outlook and I have been importing into new versions of outlook for years.
Is this the case? And if so, is it safe to import all of that data (about 1gb) into a newer PST file to correct this problem?
Thanks in advance!
Do you get any error messages when you try to set it as default? If you Add a new pst file, can you set it as default? If so, import the old pst into the new default pst.
It is safe to import the contents of the old pst. Custom views and custom forms won't import, but that's only a problem if you are using either and if the old pst is ansi, you need to move the contents into a Unicode pst.
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
T Why is every new email pinned (to keep it on top)? Windows 10 Using Outlook 6
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
Scorpion New Contacts keep coming up as company Using Outlook 1
R Can't keep emails synced on various devices Using Outlook.com accounts in Outlook 4
piusg 2013: Task Views keep disappearing Using Outlook 4
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
S how to keep "To" when move sent emails to other folder Using Outlook 1
K Deleted emails keep coming back Using Outlook 3
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
A outlook trying to keep sending Using Outlook 1
B Closing Exchange service, how to keep all calendar and mail data? Exchange Server Administration 0
D How to keep Outlook 7 open to full screen Using Outlook 2
Z Keep Unread Messages in same folder Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P emails with attachments keep sending... HELP!!! Using Outlook 4
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
N Contact Groups - names keep changing from Contacts to AddressBook Using Outlook 5
M Reminders keep coming to users' calendar Exchange Server Administration 1
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
S Reminders keep popping up, even after dismissing them Using Outlook 9
P deleted items keep reappearing in my deleted folder Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
A How to keep all conversations expanded? Using Outlook 3
S Deleted messages keep coming back Using Outlook 7
A Keep format of message in the body Outlook VBA and Custom Forms 1
R keep track of the original sender Outlook VBA and Custom Forms 3
R Deleting Synchronisation of Old Accounts Using Outlook.com accounts in Outlook 0
