Custom .oft / Printing Issue(s)
CatShannon
Outlook 2007
Hi all,
In OL2007 I created a custom form. I am very much interested in printing it WYSIWYG. This is not a complicated form. It basically contains title of the field & the field that needs to be filled in. Both Clients will want to print some assemblance of the Form they received.
When I do a print preview I get named User-Defined Fields that I deleted. Is there a way for WYSIWYG printing?
Thanks for your support!
Forms don/t print as you've discovered. You'll need to send the data to a template that is laid out like the form or use print screen.
What type of form is it? Were the user defined field deleted from both the folder and the form?
P outlook 2007 - custom buttoms with hyperlinks to oft files Outlook VBA and Custom Forms 1
E Custom formula for columns Using Outlook 3
witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
O Searching for Custom Flags Using Outlook 3
P Outlook custom fields "events" Using Outlook 0
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
