Add to Calendar links - auto accept with macro
webster20
As a manager, I get emails when my associates book travel and I get a notification with the itenenary. In the email, there is a link that says Add to Calendar.
When you click on that link. It will end up giving you an ics calendar to add to your calendar.
Is there a way with a macro to automatically add this information to my calendar with one addition which is the addition of the associates name to the subject of the invite?
The default subject just states Travel Itenenary. If you have more than one person you manage then you can see how that isnt enough detail.
Any help is appreciated.
C Delete Subject-Add Organizer to all Reservations in Default Calendar. Using Outlook 0
Diane Poremsky Send an Email When You Add an Appointment to Your Calendar New Slipstick.com Articles 0
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
anoble1 How to create an email with a link to add a calendar appointment Using Outlook 1
M Add small calendar to navigation Using Outlook 1
D Add color to calendar items automatically? Using Outlook 1
D Cannot verify or add the calendar to Outlook Using Outlook 6
H add an appointment for a custom calendar, vba excel Outlook VBA and Custom Forms 2
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
B Task Filter Not Working When I add too many criteria Using Outlook 0
