Outlook 2003 forms problem
Oldmaven
When I was running Outlook 2003 under XP, there was a Choose Form option on the toolbar. Now that I'm running it under Win 7, there isn't. So instead of clicking on it directly, I have to click File, then New, then Choose Form. How do I get it back on the toolbar?
While I'm at it, how do I make my form more prominent? At the moment, from Choose Form I have to navigate down to User Templates in File System, then navigate down to the one I want. It would be a smidge more convenient if I could either move it to the Personal Forms Library (or, better yet, the Standard Forms Library, which is the default) or simply make User Templates the default.
Oldmaven
And it would be even better if I could arrange for the template to suppress my signature, as I don't use it on that form.
O Outlook custom forms (2003) Using Outlook 5
L Outlook 2003 Forms Outlook VBA and Custom Forms 1
I Outlook 2003 shows html code when To: field is empty Using Outlook 6
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
R Outlook 2003 not working Using Outlook 13
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
K outlook 2003 address book Using Outlook 25
