How do retention policies work with .pst files?
kmfdm
I have a very strict retention policy (60 days) and I am trying to archive emails past that point. I can copy .msg files to a local fiolder, but I have no way of sorting by received date then.
If I export the emails to a local .pst file, is that file still affected by the retention policy? Meaning, is the retnetion plocy still tied to the individual email after it is exported as part of a .pst?
or will I open the .pst file 6 months form now and see all the email be removed?
Thanks...
kmfdm
Thanks, that is very helpful. I'm going to try out that VBA tonight.
Just so I'm understanding you correctly, though - you stated that retention is exchange server mailboxes only...so if I do end up exporting to a .pst, the emails are safe and will not be affected by the retention policy, correct?
Correct. When the mail is moved to the pst, the policy does not apply - the policy feature looks only in the mailbox, it can't see what is in the pst.
kmfdm
I added the code and I can't get it to work. I tried both adding a new module and adding it to ThisOutlookSession.
I get a runtime error: "Operation Failed"
Debug points to this line: oMail.SaveAs sPath & sName, olMSG
I didn't know if the path was correct, so I then tried to set the path to "C:\Temp". The new error was "You don't have permissions to perform this action".
I checked tried this with various settings under Macro Security - no change. What am I missing here?
kmfdm
Since this is now a programming issue and the programming forums here appear to be closed, I posted the question in the Outlook MSDN forums. Hopefully I can figure it out.
Does it work if you use a different path, like my documents?
kmfdm
Thanks for the reply. I tried that as well, since the code as written (using "Documents" instead of "My Documents") didn't seem to work with WinXP.
Neither way worked.
kmfdm
I changed it to a test folder in My Documents and it worked now. Strange.
All set now...thanks for the help!
Yeah, that could be a problem since My Documents is in a different path. I'll check it on a Windows xp system.
I have to put together a winxp/2007 virtual machine, but on winxp/2010, using the code on the webpage, exactly as written but changing the sPath to
sPath = enviro & "\My Documents\"
works here. It *should* work in 2007 too.
If i use a path that does not exist, i get this:
Run-time error '-2147287037 (80030003)':
The operation failed.
In the VBA editor, press Ctrl+G to open the Immediate window. If there isn't anything shown, run the macro. The Debug.Print sPath & sName line creates this list of files, one for each selected message or for the first message, if the macro fails on the path. Does the path exist?
I Retention policies on outlook 2016 ribbon Using Outlook 2
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
R Retention periods and Deleted Items Using Outlook 7
N Outlook dialog about retention policy Using Outlook 3
M Microsoft SW Licencing policies BCM (Business Contact Manager) 2
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S What's in a PST file? Using Outlook 1
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
N Two .pst files on one computer both with contacts? Using Outlook 9
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
E Exporting email (.pst) Using Outlook 8
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
E How to transform .OST in .PST ? Using Outlook 1
O Any decent tool to compare .pst files? Using Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
