View zoom setting changing
Vincenzo
My friend's Outlook 2013 new email dialog keeps ending up zoomed out (so that the signature appears very small on her screen, but is ok when the recipient gets it) even though she is not aware of doing anything. I have reset it for her a few times. I suspect that perhaps she is doing it by accident with the mouse wheel? Or is there another way this could be happening? And is there a way to lock the view setting so that this will not happen? Thanks
She is likely doing it by accident with the wheel. When it happens in a compose form, the zoom setting is saved and the next message will be affected too.
I'll have to check and see if you can disable zoom - but it means it will never work, even when you want it to. It would be better to figure out what she's doing to change it so frequently, so she is aware of it.
J Weekend View in Calendar Using Outlook 1
B See "Change View" Drop Down as a List? Using Outlook 1
B How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Calendar Printing Assistant 1
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
B outlook view control Outlook VBA and Custom Forms 0
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Disable Protected View for Outlook Attachments New Slipstick.com Articles 0
M How to view the URL for a hyperlink? Using Outlook 1
Diane Poremsky How to View Internet Headers New Slipstick.com Articles 0
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
M contact marked as completed in phone view but not when opened Using Outlook 2
L Change the displayed fields in calendar view Using Outlook 1
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
O highlighted dates in Yearly View for Outlook 2010 Using Outlook 1
A Quick Steps in Tasks view Using Outlook 7
Diane Poremsky How to View a Shared Calendar on a Smartphone New Slipstick.com Articles 0
D Creating custom view with VBA Outlook VBA and Custom Forms 2
