Outlook Prf/Automation question
tbone587
Hello all, I am somewhat new to outlook automation and have created my first prf file to automate the creation of a new mapi profile for an exchange account. Everything is working as expected, however when i run the /importprf command and it launches outlook for the first time, it is popping up a window asking for username, password, and a checkbox to remember credentials. Can you please answer the questions below?
  1. Is there a way to populate the username field via the prf or a vb script?
  2. Is there a way to populate the password field via the prf or a vb script ( I assume no )?
  3. Is the only way to import a prf file by command line using the outlook.exe/importprf flag?
Thank you very much!
1. You can use variables UserName% gets the current logged in user. You can also server variables in paths:
OfflineAddressBookPath=%localappdata%\microsoft\outlook\
2. no.
3. You can use a command line in this format:
Outlook.exe /importprf \\server1\share\outlook.prf
tbone587
Thank you very much for the quick response. Can you please elaborate on your response for question 1? I currently have the variable below set with the email address and that works, however after running /path/outlook.exe/importprf outlook launches and it prompts for the user name and password. Im trying to insert that information via the prf to have one less thing to type.
; Section 4 - Default values for each service.
MailboxName=customer@domain.com
; Section 6 - Mapping for profile properties
[Microsoft Exchange Server]
MailboxName=PT_STRING8,0x6607
2. no.
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
R Ingest contact PST from exchange 2007 thru client's Outlook via PRF Exchange Server Administration 2
K Editing a .PRF file for new users after deploying Outlook 2010 with MSP Using Outlook 5
N Outlook 2007 - Set account to send only with .prf file Using Outlook 1
B Outlook Using Outlook 0
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
