Outlook VBA rule script to process both MailItem and MeetingItem
se2k
Is there a way using Outlook VBA to have a rule script process both "MailItem" and "MeetingItem" types?
All the code examples I have seen either specify "Item As MeetingItem" or "Item As MailItem", but I need to process both meeting items and mail items. Is there some sort of "OR" condition I can use? What would be the proper syntax to do this?
Any help would be appreciated!
Gary Brown Outlook 2013 VBA to run a rule Outlook VBA and Custom Forms 13
R Outlook 2003/2007 Rule and Conditions for InBox VBA customization Outlook VBA and Custom Forms 3
K Re: Cuestom outlook rule using vba Outlook VBA and Custom Forms 4
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
T Outlook AntiSpam with VBA Outlook VBA and Custom Forms 1
F "Move to" O365 feature to Outlook client via VBA Outlook VBA and Custom Forms 4
J VBA to switch Outlook online/offline Outlook VBA and Custom Forms 4
T VBA outlook, detect priority emails Outlook VBA and Custom Forms 5
S Outlook VBA Contacts Notes Outlook VBA and Custom Forms 0
O VBA or other solution for Outlook tasks to OneNote Outlook VBA and Custom Forms 0
