Intermittent ability to send to single domain. "Connection refused"
kscott004
Outlook 2007
When attempting to send mail to a particular domain, the firewall mail log returns "connection refused by" their smtp server. Occasionally a message will send through without a problem, the external domain can send to us no problem, the DSN in the mail log is returned as 4.0.0 deferred, and messages generally send about one day later from what I understand (however I have not personally verified this yet). I've double checked the queue length and there are no messages in the queue. The traffic is making it to their smtp servers and is being refused.
Any ideas on what I can check?
Thank you,
Karl
The admin at the other domain would have more information and his logs should say exactly why it was refused. But I'd start with checking the blacklists - make sure your smtp server isn't on it. Their server could be overloaded, your server could be too talkative and mistaken for a spammer.
Do you have spf records for your domain? If you use more than 1 smtp server, is there an spf record for each?
E Multiple, intermittent Outlook 2010 errors Using Outlook 12
G Outlook Intermittent Issue with Drafts not Displaying Entire Content Using Outlook 4
E intermittent "Your imap server closed the connection" messages Using Outlook 6
C New mail icon on taskbar intermittent Using Outlook 1
J Ability to notify attendees when canceling past meeting is gone Using Outlook 1
A Add Contact to Public Folder Ability Outlook Wishlist 3
A the ability to follow links in E-mail from within MS Outlook Using Outlook 1
N Business Contact Manager - Ability to use BCM (Business Contact Manager) 8
A ability to add comments to frequently used fields of a contact Outlook Wishlist 0
P Ability to define shortcuts to folders Outlook Wishlist 2
glnz O365 - How to send from acct 2 but showing email name from acct 1 as From - alias? Using Outlook 1
F Send As a Gmail account via outlook Web Using Outlook 3
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
M Can't send email in outlook.com Using Outlook 9
R Can't Send calendar share invite Using Outlook 5
R Can't send messages to groups in Outlook Using Outlook 2
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
