Outlook 2013 To Do Task does not minimize.
SloopJohnB
Outlook 2013 64 bit
I will like to miminize the to do tasks like in Outlook 2010, under To Do Task you could minimized it to show on the right hand side.
santheocles Issue in Outlook 2013 - cannot reschedule single task Using Outlook 0
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
F Combine Outlook Task Folders into one View (Outlook 2013) Using Outlook 3
K Starting Outlook 2013 x64 minimized in Win 8 with or without Task manager Using Outlook 5
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 9
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
M OUTLOOK 2013 CONTACT PROPERTIES Using Outlook 0
M Outlook 2013 Using Outlook 1
J Outlook 2013 hanging for unknown reason Using Outlook 1
K Rebuilding Outlook 2013 from Outlook.com after OS rebuild Using Outlook.com accounts in Outlook 2
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
