How do I start completely from scratch in setting up Outlook 2013?
Dr_very_Evil
Outlook 2013 32 bit
Outlook.com (as MS Exchange)
Hi there
I have kind of an annoying problem: I've just purchased and set up Outlook 2013, and made a few mistakes, it seems. One of them was importing several .ics calendars - and now I can't delete them anymore. (There doesn't seem to be a solution. Once you import such a calendar, it is there to stay. They're not online calendars, I had them on my PC as files and imported them).
So I thought: Well, no problem, let's just start from scratch. Nothing much lost, yet.
Not so easy, it seems. I ended up uninstalling the whole office suite (Office Home&Business), even using Microsoft's fixit to really get rid of everything. After that, I re-installed office.
But: The SAME Mail accounts, the same settings overall - and, most annoyingly, the same useless calendars I really don't want - were here again. Like magic. Black magic. I really desintalled everything. I used the fixit. I restarted the machine...
So, dear forum: what can I do to really start from scratch? So that I can set up all my stuff like Outlook was new?
The calendars are in the mailbox and when you open the mailbox, they will download... or you are using the old profile.
Are they separate calendars or appointments/events in one calendar? Try using a list view on the calendar, add the last modified field to the view and sort. Are the events you want to remove sorting together? If so, select the first one, hold shift and select the last then delete.
If they were opened as ics files and are in their own data file, you can delete them from File, Account Settings, Internet Calendar.
If you really want a new profile, close outlook, go to control panel and search for Mail. Delete the profile and make a new one - but if the calendars are in your mailbox, it won't help.
FWIW and for next time, uninstalling rarely fixes problems...
Dr_very_Evil
Outlook 2013 32 bit
Are they separate calendars or appointments/events in one calendar? Try using a list view on the calendar, add the last modified field to the view and sort. Are the events you want to remove sorting together? If so, select the first one, hold shift and select the last then delete. .
Thank you very much for your reply. I don't know much about calendars, admittedly. Here's what I did: I opened Outlook. I set it up using my Outlook.com account. Next, I wanted to import a few calendars from my Mac days. In the end, I collected 5 .ics calendar files which I wanted to integrate in Outlook. Preferably NOT as separate calendars, but all unified in my main (default) Outlook calendar. But here's what happened when I opened/imported the .ics files from my hard drive: A new, separate calendar was created in Outlook - and one I can't delete anymore (the delete button is greyed out). This is obviously very annoying. I will never again click on a .ics file on this computer.
No, this is not possible, unfortunately. There are no calendars showing up in the Account settings. No Internet calendars, and no shared ones.
Thank you again. This is what I did, so I now have a new profile, just need to figure out how to merge my calendars with the main Outlook.com calendar (which is my default) without creating any new non-deletable items in Outlook 2013. And yes, I'll keep that in mind with the re-installing :).
Try using File, Open & Export - and import the ics files.
Dr_very_Evil
Outlook 2013 32 bit
I have by now found out the root of my problems, I think: It seems it's a "feature" of the new Exchange ActiveSync protocol (EAS 14.0).
http://support.microsoft.com/kb/2781261/en-us
Well, that's it for me then, Outlook is not for me. I can't believe it. An outlook.com address in Outlook 2013 means you can't even have rules to move mails from other accounts into your main inbox. Because you can't. Because the new protocol doesn't allow it. Argh, back to google it is then. I don't want to, but this is ridiculous.
Dr_very_Evil
Outlook 2013 32 bit
That's actually a good idea. I'll do that, thanks.
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
N Multiple instances of Outlook on Start Menu Using Outlook 2
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
P Outlook 2016 won't Start Using Outlook 3
O Outlook 2016 crashes at start Using Outlook 14
S Calendar loops when clicking on calendar link to start it Using Outlook 1
Diane Poremsky Cannot start Microsoft Office Outlook Error Message Using Outlook 0
Thorsten show the correct calendar on start Outlook VBA and Custom Forms 5
V Cannot start Outlook. Cannot open the Outlook window. Using Outlook 8
M Cannot start MS Office Outlook Cannot open the Outlook window Using Outlook 2
R Default Start time for Private Appointment Using Outlook 4
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
E Searching a Shared Outlook Mailbox from the start menu? Using Outlook 4
S Using "start application" rule action Using Outlook 2
A BCM does not start correctly BCM (Business Contact Manager) 10
M Clipboard Manager Not showing in Outlook 2010 on Start Using Outlook 8
L Outlook 2007 does not start with Apple iCloud-Add-In activated Using Outlook 2
V How can I start a NEW PST file without loosing my contacts & other data Using Outlook 3
P Outlook 2010 fails to start after icloud update Using Outlook 3
C Monday Start Monthly Template Using Outlook 0
L Change length of appointment start time Using Outlook 2
G Cannot start Microsoft Outlook Using Outlook 1
M I cannot start Microsoft Outlook 2013 directly opening a .eml message Using Outlook 1
E Adding Start and End Time to Daily View in Calendar Printing assistant Using Outlook 1
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Task Start and Due Dates Using Outlook 3
R Changing Start Date Without Changing Due Date in Tasks Using Outlook 1
M Outlook wont start Using Outlook 1
N How can i hsve appointments and events to not display start or finish times Using Outlook 2
W Auto changing "You" at start of sentence...very frustrating! Using Outlook 4
E cannot start Microsoft Office Outlook. Cannot open the Outlook Window. Using Outlook 1
G How to NOT display the start time in monthly calendar view - 2007 Using Outlook 8
J Outlook 2010 won't start in Win 7 Using Outlook 4
S Cannot start Microsoft Office Outlook. Cannot open the Outlook window. The set of folders cannot be Using Outlook 3
S __Cannot start Microsoft Office Outlook. Cannot initialize Microsoft Office shared utilities.____ Using Outlook 4
N Start my Outlook from a server Outlook VBA and Custom Forms 1
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
T MSSMLBIZ will not start after a Windows XP Repair BCM (Business Contact Manager) 4
T Cannot Start MS Office Outlook - Cannot open office window BCM (Business Contact Manager) 1
R Phone Call Start Date - Phone Log BCM (Business Contact Manager) 1
M Phone Message form in outlook 2007. How to start? Outlook VBA and Custom Forms 2
