Outlook 2007 Code for Note Fields of Appointment
LMS
I have a contact form with the script that creates a calendar event for the contact I open and uses the fields of the contact re dates and subjects and locations and adds them to the appointment ....
I learned to add to the script code, a line that will put in the note field of the appointment, the phone numbers of the contact ....and I have title before each phone number....so all i need to do, is have the second phone number and related title be below the first phone number and title, so its two lines, not just one line....so here is the code line that takes care of the note field, but need to put something in so it makes it two lines in the note field of the appointment.
itmAppt.Body = "Mobile Number" & " - " & item.getinspector.modifiedformpages("General").controls("Phone4").text & " " & "Business Number" & " - " & item.getinspector.modifiedformpages("General").controls("Phone1").text
Try vbcrlf or vbcr -
itmAppt.Body = "Mobile Number" & " - " & item.getinspector.modifiedformpages("General").con trols("Phone4").text & vbcrlf & "Business Number" & " - " & item.getinspector.modifiedformpages("General").con trols("Phone1").text
As an FYI, you can use the chr code too -
Chr(10) or vbLf = Line Feed Return
(Chr(13) or vbCr Carriage Return
vbCr Lf = Carriage return line feed.
LMS
What you first showed did it right away...thanks so much...and I assume if I wanted to line spaces, just repeat that...correct?
LMS
And forgot to ask...if any phone area in the contact does not have phone number is there a way adjust the code so I does not to display the title name as there is not phone number??
you put it at the end of the line where you want to break - use & vbcrlf & - just like you would if you were using a space.
If you use chr, it's done the same way - put & chr(13) & where you want the break.
LMS
and if any phone area in the contact does not have phone number is there a way adjust the code so it does not to display the title name as there is not phone number??
Yes, repeat the line break for additional line
& vbcrlf & vbcrlf &
You can use an if statement - it can sometimes be goofy if the field had a number then you removed it.
if item.getinspector.modifiedformpages("General").con trols("Phone4").text <> then
end if
if item.getinspector.modifiedformpages("General").con trols("Phone1").text <> then
"Business Number" & " - " & item.getinspector.modifiedformpages("General").con trols("Phone1").text & vbcrlf
end if
LMS
So I replace the code line I have with these two lines??
LMS
I replaced my line with you lines, and the error is "syntax error" as to the if statement
oh, i wonder if its the greater and less than signs - i used html code because the forum software hides the characters but i see now that it didn't convert the code.
You need to check the field to see if its empty and I think an if statement would be the easiest way to do this.
LMS
So what exactly do put in and do i take out the code i showed you? So please show me the details of what it is and I will test it.
this *should* work -
if item.getinspector.modifiedformpages("General").controls("Phone4").text <> then
"Mobile Number" & " - " & item.getinspector.modifiedformpages("General").controls("Phone4").text & vbcrlf
end if
if item.getinspector.modifiedformpages("General").controls("Phone1").text <> then
"Business Number" & " - " & item.getinspector.modifiedformpages("General").controls("Phone1").text & vbcrlf
end if
LMS
So do I keep in the code line I showed you or delete it?
I'm not sure what you mean - i only see the one with the mobile and business number fields.
LMS
The one you see that I showed do i replace it with your lines or add your lines before or after it?
LMS
I did it, but it is still the same error.....and below is the full code that maybe will to understand what to change:
Sub btnAddCalendarEvent_Click
dim ContactName
dim olns
dim MyFolder
dim NumItems
dim myItems
Dim StartDateTime
Dim EndDateTime
Dim ShowAs
Dim itmAppt
ContactName = Item.GetInspector.ModifiedFormPages("General").Controls("Fullname").value
Set olns = Item.Application.GetNameSpace("MAPI")
Set myfolder = Session.GetDefaultFolder(9).Folders(2)
Set itmAppt = myfolder.Items.Add("IPM.Appointment.Office Calendar Event")
itmAppt.Subject = ContactName & " - " & item.getinspector.modifiedformpages("General").controls("combobox11").text
itmAppt.Location = item.getinspector.modifiedformpages("General").controls("combobox12").text
itmAppt.Body = "Mobile Number" & " - " & item.getinspector.modifiedformpages("General").controls("Phone4").text & vbcrlf & "Business Number" & " - " & item.getinspector.modifiedformpages("General").controls("Phone1").text
StartDateTime = item.getinspector.modifiedformpages("General").controls("OlkDateControl1").value & " " & item.getinspector.modifiedformpages("General").controls("OlkTimeControl1").text
itmAppt.Start = StartDateTime
EndDateTime = item.getinspector.modifiedformpages("General").controls("OlkDateControl2").value & " " & item.getinspector.modifiedformpages("General").controls("OlkTimeControl2").text
itmAppt.End = EndDateTime
ShowAs = item.getinspector.modifiedformpages("General").controls("combobox13").value
Select case Showas
case "Free"
ShowAs = 0
Case "Tentative"
ShowAs = 1
Case "Busy"
ShowAs = 2
Case "Out of Office"
ShowAs = 3
itmAppt.BusyStatus = ShowAs
itmAppt.links.add item
itmappt.display
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
K Outlook 2007 Error Code 0x80040607 Using Outlook 10
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
