View Reading Pane for Drafts folder
Y
YXJhdWNhcmlh
Hello:
Microsoft Office Outlook 2003 (11.8206.8221) SP3
Does anyone know how I can turn on the reading pane for the drafts folder ??
I tried:
View > Arrange By > Current View > Customize Current View
In the Customize View: Messages Dialog, Select the "Other Settings ... "
button
In the "Other Settings" Dialog, Select Reading Pane "Bottom"
Press OK, Press OK
NOTHING HAPPENS !
I seem to be able to get a reading pane for all other folders.
moorpheus
Never overlook the stupidity of Microsoft. This has been disabled to prevent your convenience.
Many of the helpful things that were in Outlook Express (OE) and that should continue to be an option have been disabled so only highly experienced computer users can have full use. Every other program I know of allows viewing of attachments and photos in drafts. Not Outlook, which is purportedly more "advanced" than Outlook Express.
MS seems devoted to making "updated" versions that cost money and deliver less and less. Further, since OE was quite satisfactory, (except the search/find) and easily used by anyone, they have prevented use with "updated" OSs. I just don't get their strategy and don't like their apparent desire to annoy and confuse.
J Split reading view with history Using Outlook 2
Commodore MHT files (from "View in browser") Using Outlook 7
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Using Outlook 1
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
B outlook view control Outlook VBA and Custom Forms 0
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
