Best way to locally backup/archive Gmail?
pkcouch
I have Outlook 2010 with an IMAP/Gmail account. I've had GMail for many years and it is approximately 4GB “in the cloud”. In my Send/Receive Groups, I have all of my GMail folders (except All Mail) setup to download headers only (Send/Receive Settings – All Accounts).
I was wondering about how to institute overall local backup/archival strategy as it relates to Send/Receive Groups. Or if this is even the correct approach? I am interested in preserving my email in a PST in the event that my Gmail in the cloud “goes away”. Would it be better to change the Send/Receive settings to ‘download complete items including attachments for subscribed folders’? Or is there a better/different way to do this with the Auto Archive or another feature?
[FONT=&quot]Thanks, Paul c.[/FONT]
You need to download full messages to use an IMAP data file as backup.
In Outlook 2010 and older, you can copy the imap pst file as a backup - the pst data file can be opened in any outlook profile. Messages without bodies will be in the data file, but outlook won't be able to get the body. This is generally easier than exporting the pst for backup, except export should get the full messages, if any are missing the bodies. Export can be filtered, so you could export weekly and change the filter to include only new messages.
As an FYI, Outlook 2013 uses an ost file for IMAP, so this trick no longer works - you'd need to export the folders to backup IMAP in Outlook 2013.
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
