"database is not compatible with BCM for Outlook 2013" & more
GabrielleN
Outlook 2013 32 bit
I seem to be having multiple issues with BCM for Outlook 2013 and am hopeful that someone else has been successful in getting this thing to run consistently. (And, btw, my enter key doesn't seem to work in this forum. Everywhere else though! So please forgive this messy message) ....
I'm running Outlook 2013 32 bit on Windows 8-64 bit
1 - After several tries, installing, then uninstalling, running a complete uninstall using REVO and Agent Ransack, it appears that I finally have an almost running copy of BCM. However, it appears that intermittently the Add-in for BCM does not load. When that happens "sometimes" I can re-enable the Add-in, close Outlook and then restart. Then BCM will be back. Othertimes, however, BCM just refuses to load and I get an error when starting that says "cannot complete the selected action because an unknown external error occurred." Then I have to uninstall and reinstall again. Is there any known cure for this, or is this a typical BCM for 2013 issue and I should give up?
2 - Could issue #1 be related to an old 2008 SQL Server version that is installed when BCM is installed?
3 - When starting BCM, I told it that I would create a new database. So when BCM "does" decide to start up with Outlook, the database is empty. But there's an error message at the top of each screen that says "This database is not compatible with Business Contact Manager for Outlook 2010." BCM is not installed with any other outlook version, although I do also have Outlook 2010 installed on this system. Is there a fix for this message?
Thanks so much for your help. Again, sorry for the funky display here. What's with this no enter key stuff on this forum?
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
wallisellener "The database name cannot exceed 50 characters" BCM (Business Contact Manager) 2
S Encrypting Exchange Database Exchange Server Administration 0
R Outlook Database to a non-Outlook PC Using Outlook 10
A use database in other office BCM (Business Contact Manager) 1
K Recover/preserve space in database BCM (Business Contact Manager) 0
P Restoring old sbb database in existing one BCM (Business Contact Manager) 4
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
M Sharing of BCM database across the internet BCM (Business Contact Manager) 2
Chris Grew Sharing BCM Database BCM (Business Contact Manager) 6
S Updating the database based on received task Outlook VBA and Custom Forms 3
J What exactly does the BCM Database tool actually do? BCM (Business Contact Manager) 3
J How do I get the database tool to recognize my data file? BCM (Business Contact Manager) 2
C Moving BCM Database to Server Share BCM (Business Contact Manager) 1
D Open attached CSV, copy newdata and paste it to database CSV Outlook VBA and Custom Forms 2
K BCM - Connecting to Shared Database BCM (Business Contact Manager) 0
B Can't see database in multiuser BCM (Business Contact Manager) 1
S Passive Mailbox database Resynchronization issue Exchange Server Administration 1
J Can the BCM Database tool be used over VPN? BCM (Business Contact Manager) 6
D can you share a bcm database with 2 different versions of windows? BCM (Business Contact Manager) 0
T BCM database scheme BCM (Business Contact Manager) 5
E BCM Database Tool Using Outlook 2
L BCM database not listed BCM (Business Contact Manager) 0
wallisellener database creation failed BCM (Business Contact Manager) 0
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
P BCM 2013, Microsoft SQL Server 2008 R2 (SP2), attachment issue n database size BCM (Business Contact Manager) 2
T BCM Cannot See Existing Database BCM (Business Contact Manager) 2
R catalog Content Index failed-Unable to mount database.(hr=0x80004005,ec=-501) Exchange Server Administration 0
T Shared BCM database on remote server BCM (Business Contact Manager) 1
C My BCM Database is no longer available to be shared with the Database Tool BCM (Business Contact Manager) 3
wallisellener Server configuration for BCM 2013 shared database BCM (Business Contact Manager) 15
S Cannot Find Shared Database on Remote Computer BCM (Business Contact Manager) 13
M BCM in Outlook reports maximum database size to 4GB despite SQL Server 2008 R2 BCM (Business Contact Manager) 1
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
A delete database --> record remnants ?? BCM (Business Contact Manager) 3
D BCM Database Protection BCM (Business Contact Manager) 3
U Exchange 2010 & mailbox database Quotas Exchange Server Administration 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
J Unable to view History items in BCM 2007 shared database BCM (Business Contact Manager) 3
E Accessing User Defined Fields in BCM Database part 2 BCM (Business Contact Manager) 0
E [SOLVED] Accessing User Defined Fields in BCM Database part 1 BCM (Business Contact Manager) 9
