VBA Code to extract data from an Outlook Form
maxwello
Outlook 2007
I have designed an outlook form for people to populate (It has several tabs and multiple data is populated in each tab) and send to another team. I already have a MACRO that extracts data from the old emails that is held in the email body however now I would like to tweak the MACRO to extract the data from the form. Is this even possible? I have seen people speak about InfoPath but this isn’t an option for me so I would really appreciate it if anyone has any advice.
Regards
Maxwello
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
Kelli VBA code for Outlook Using Outlook 1
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
J VBA code to determine 'show' state of SearchBar Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
S ThisOutlookSession in VBA not there anymore and code is gone Using Outlook 2
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
N VBA code to show today's date + a sequencial number in subject lin Outlook VBA and Custom Forms 1
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
P 'Trusted' VBA code in Outlook 2003? Outlook VBA and Custom Forms 2
F Recovery of VBA code Outlook VBA and Custom Forms 2
