Outlook 2003 I need to move email to folder based on subject, using wild card
Glenn
I need to move email to a folder based on “subject”, subject will have “work order 1234 ” but the last 4 digits will change, (work order 1235)
The VB needs to move mail EG: “.Folders (“Personal Folders”).Folders (“work”).Folders (“Daily Orders”) based on subject *
I have been trying to use code ( Like "Work Order*" Then ) do move.
This code needs to reside in the click event.
I have been racking the brain for a few days, I can move email if “subject” does not change and “from” or “email address”
Thanks in advance
M Outlook 2003 - accidentally deleted a distribution list, need to undelete Using Outlook 4
M Need to take names and email addresses from excel 2003 and put into outlook to email. Using Outlook 4
J I need to set up AOL on Outlook 2003 Using Outlook 1
C I need to transfer contacts files from Outlook 2003 with Windows XP Pro to a new laptop using Outlook 2007. Thanks for any help. Using Outlook 1
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
R Outlook 2003 not working Using Outlook 13
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
