Exchange 2003 how to stop accepting EHLO and AUTH commands
adrian.aitken
Outlook 2013 64 bit
Spammers are breaking a clients Exchange 2003 server by flooding it with EHLO/AUTH commands which are rejected but eventually locks the SMTP service and I had to write them a batch file to kill inetinfo.exe (the standard iisreset command would hang). The log files always show EHLO so can I tell Exchange to block that command? I've already enabled the 'send HELO instead of EHLO' option but need a 'only receive HELO not EHLO' tickbox :)
Many thanks
Adrian
B Exchange 2003 EDB corrupt Exchange Server Administration 6
A Rename resource Exchange 2003 Using Outlook 2
R Exchange 2003 to 2013 mail Exchange Server Administration 4
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
T Exchange 2003, NDR, DNS problems Exchange Server Administration 3
K clear categories on Exchange 2003 & Outlook 2003 Exchange Server Administration 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
S How to leave e-mail on Exchange 2003 server? Exchange Server Administration 1
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
J I use Windows XP with Microsoft Outlook 2003 and I cannot get int the Microsoft Exchange server. Using Outlook 1
B Move mailbox from Exchange 2003 to 2010 Exchange Server Administration 2
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
K on outlook 2003, how do I set up an out of office reply if I do not use the exchange server Using Outlook 2
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
S exchange 2003 org to exchange 2010 org Exchange Server Administration 2
T Outlook 2003 thinks I'm connected to and exchange server. I'm not. How do I reset Using Outlook 1
H Unable to remove the last exchange 2003 server in the organization Exchange Server Administration 2
M Inbox is not syncing correctly between OWA and Windows 7 Client with Exchange 2003 Using Outlook 4
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
C Outlook 2003 (or Exchange 2003): Automatically coptying someone on outbound email Using Outlook 2
C Mail folder permissions Exchange 2003/Outlook 2003 Using Outlook 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
A I have purchased a replacement computer and installed Outlook 2010. My server is a 2003 small business exchange server. How can I access the calenda Using Outlook 1
M Exchange 2010 Outlook Web App via Exchange 2003 Front End Server Exchange Server Administration 1
J Exchange server 2003 to 2010 Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
B Entourage and Exchange 2003 SP2 Using Outlook 1
D Unable to search contacts in Outlook 2003 - Exchange 2010 Using Outlook 2
I Win 2003 AD Exchange 2003 upgrade Exchange Server Administration 6
D Users migrated from exchange 2003 cannot manage Distribution lists from Outlook Exchange Server Administration 7
J Understanding Exchange 2010 <-> Exchange 2003 Connectors....help... Exchange Server Administration 4
W Outlook 2010 Free/Busy Data not updated\viewable - Exchange 2003 SP2 Using Outlook 2
D Exchange 2003 to Exchange 2010 mail stuck in Exchange 2003 Local Delivery Queue Exchange Server Administration 10
S garbage mail recieved from Exchange 2010 HUB to Exchange 2003 user. Exchange Server Administration 2
I Copying mailboxes from Exchange 2003 to Exchange 2010 Exchange Server Administration 3
