DAG question
stoneaj
New member here hello! I would like to know from one of you pros what the proper placement of the share witness would be in the following setup.
Datacenter A: 1 CAS server and one mailbox server -active
Datacenter B: 1 CAS server and one mailbox server -passive
If we should drop connection between A and B from some reason... What would the correct placement of the fileshare witness be to prevent split brain.
Thanks for any help you can provide. :)
EDIT: Wrong forum :( sorry. I meant to post this in the the Exchange forum not OWA.
L DAG Question - Help Exchange Server Administration 2
J Question of Exchange 2010 DAG Exchange Server Administration 3
M DAG layout and space question Exchange Server Administration 2
B Two server DAG setup, second server EMC not opening Exchange Server Administration 3
L DAG Requirements Exchange Server Administration 5
G Mount recovery database fails on DAG Exchange Server Administration 3
S Mailbox Stores not mount in Two Member DAG Exchange Server Administration 4
P DAG CONFIGURED Need to change the data base and log file location .What are the risk .And Steps to p Exchange Server Administration 3
A Exchange DAG Exchange Server Administration 1
V mapiexceptioncallfailed: unable to mount database when activate mailboxdatabase in dag Exchange Server Administration 4
S DAG Content Index failed Exchange Server Administration 2
E Outlook 2007 won't connect to 2nd Mailbox Server in a DAG Exchange Server Administration 2
S DAG with Single Network Card Exchange Server Administration 8
T Exchange 2010 DAG Failover Issue - Database Activation Fails because Content Index Catalog Failed Exchange Server Administration 2
A Access a DAG over a virtual lan ip for backup Exchange Server Administration 1
M Hyper-v vSwitches and DAG Networks Exchange Server Administration 7
A Need Help Urgent !!!- Add Seconde Node To The DAG Exchange Server Administration 12
P 2 Member DAG - Members Virtualised running on non Clustered Hosts - supported Configuration? Exchange Server Administration 2
P Two Member DAG - Reboot Witness Server - Effects? Exchange Server Administration 7
K Exchange 2010 DAG Exchange Server Administration 2
S DAG replicaiton and server maintenance Exchange Server Administration 6
J When a database move from active host in a DAG, user are prompted for credentials Exchange Server Administration 8
à Loss the file share witness of DAG Exchange Server Administration 4
S DAG RPCclientAccessServer Exchange Server Administration 5
K msexchangerepl utilizing high CPU in a DAG env Exchange Server Administration 10
S Extend Exchange 2010 DAG accross sites Exchange Server Administration 3
S DAG manually dismount database Exchange Server Administration 4
M Exchange 2010 DAG Witness Server Help Exchange Server Administration 2
S DAG Deployment Design with site resiliance Exchange Server Administration 2
H Shutdown all member in a DAG Exchange Server Administration 2
J DAG problem - I´m not able to recover database Exchange Server Administration 9
S Active Passive DAG seperate DNS namespace Exchange Server Administration 7
T DAG Exchange Server Administration 3
S Exchange 2010 DAG issue Exchange Server Administration 1
M Problem removing a mailbox server from a DAG. Exchange Server Administration 1
C DAG IP address Exchange Server Administration 9
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
A Unable to manage DAG Exchange Server Administration 5
M Move Mailbox from Exchange 2010 to Exchange 2010 (no DAG) - Client Outlook MAPI Profile still lists Exchange Server Administration 9
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
