iPhone Calendar will not sync with Outlook 2013
Bill Marshall
Outlook 2013 64 bit
The situation: Running Windows 8.1 with MS Office 2013, including Outlook. My iPhone is running the latest software version, 7.0.4. I am trying to sync calendar, mail, contacts, notes to the laptop using the Apple UBS. The laptop is linking to my gmail account with IMAP and working correctly.
Everything syncs successfully to/from the iPhone/laptop except Calendar. I can not get the Outlook Calendar (which contains nothing since it is a new PC and software) to “merge” with the multi-year calendar on the iPhone and in effect transfer over the iPhone calendar.
The same phone is syncing successfully with an EP laptop running office 2003, including Calendar.
Any thoughts about a solution to this would be appreciated.
Bill
V Any alternative to iCloud for calendar sync to iPhone? Using Outlook 8
K outlook calendar wont sync iphone 4 Using Outlook 1
E Outlook 2013 calendar won't sync with iphone 4s Using Outlook 14
V Sync Outlook 2003 calendar to iPhone 4 Using Outlook 2
S Using POP3, Exchange server, and iPhone sync - can't sync to POP3 calendar Exchange Server Administration 0
L Cannot sync Calendar to iphone. Cannot export to CSV. Cannot view as Table. Using Outlook 3
V Setting up windows 7 & outlook 2007 w/ Iphone 4 & synch contacts & calendar Using Outlook 9
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
A Adding Work Calendar to my iPhone 4S from Outlook 2010 and vice a versa. Using Outlook 5
U Approving Emails from iPhone Using Outlook 0
P Syncing Outlook & iPhone Calendars Using Outlook 4
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
Diane Poremsky iPhone and the Meeting Request Bug Using Outlook 0
A Folders in Outlook and Folders on iPhone 6 Using Outlook 4
M Outlook 2016 - Mail Not Syncing With iPhone Outlook App Using Outlook 1
L Synching Office 365 contacts to Iphone MS Outlook client Using Outlook 5
M Google Apps Mail *SENT* from iPhone doesn't download to Outlook via POP3 Using Outlook 1
A iPhone Contacts in Outlook won't File As First, Last Using Outlook 0
V Sync Outlook contacts with iPhone Using Outlook 4
I Outlook Contacts and Calenders not syncing between PC, IPhone, and Windows 8.1 tablet Using Outlook 3
S Best method to use Outlook Standalone with iPhone Using Outlook 13
Diane Poremsky Transfer POP3 Mail on an iPhone to Outlook Using Outlook 7
T Syncing iPhone w/Outlook Using Outlook 1
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
J Outlook 2010 - email correspondence only showing up fully on an IPhone. Using Outlook 1
R Trying to sync my Outlook email on iphone Using Outlook 1
E can't sync iPhone 4 with Outlook2010 Using Outlook 24
B Timed events created in iPhone auto-change to All Day events in Outlook 2010 Using Outlook 2
M Outlook 2010 has stopped sinking with my iPhone and iPad Using Outlook 1
J Formatting Contacts to Export for iPhone Using Outlook 0
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
M MS Outlook contacts with iPhone Using Outlook 4
P dialing from my iphone 5 using outlook address book ??? Using Outlook 1
S Sync v2003 with iPhone/iCloud Using Outlook 5
S outlook and iphone 5 Using Outlook 1
S Help needed - syncing outlook emails with iphone 4s Using Outlook 4
D Appointments from iPhone Using Outlook 2
V Sync iPhone 5 Using Outlook 5
D iPhone Alerts Don't Show Up in Outlook Using Outlook 2
J How-to setup Outlook 2010, Windows 7-32bit, iPhone (so they work and play tog. Using Outlook 3
