How to script for a recurring task
I am writing some script to automate some functions of Outlook.
I successfully allowed a specific incoming email to create a task.
What I am having trouble with is scripting that a recurring daily reminder be set until the task is completed.
this is what i have so far:
Sub ConvertMailtoTask(Item As Outlook.MailItem)
Dim objTask As Outlook.TaskItem
Set objTask = Application.CreateItem(olTaskItem)
With objTask
> subject = Item.subject
> StartDate = Item.ReceivedTime
> ReminderTime = Item.ReceivedTime
> ReminderSet = True
> Body = Item.Body
> Save
Set objTask = Nothing
Please Help
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
