bcm not showing in outlook 2013 navigation pane
koffiepit
Outlook 2013 32 bit
I use MS Office 365 Home Premium, x86. Since I did not use BCM before, I downloaded and installed the full version of the Business Contact Manager for Microsoft Outlook 2013: Full Installation for Upgrading from Business Contact Manager 2007.
However, the BCM does not show up in my Outlook 2013 navigation pane and I not see any way of accessing the BCM welcome centre, contact management, sales, marketing and other functions. I did manage to create a bcm data file account via Outlook's account settings pane. The BCM is also listed in Outlook's non-deactivated add-in programs. I use Outlook and Office in the Afrikaans language by means of the language interface pack for Afrikaans, x86.
How can I get the bcm listed in Outlook's navigation pane?
blown
Outlook 2007
Hi Diane; this tread relates to "Office 365 Home Premium" and I was wondering if BCM can be used with Office 365 Home Premium. I called MS and the rep was not very knowledgeable and just barley understandable. Could you please opine on this topic as this package has everything that I want except BCM. Greatly Appreciated by me. Thanks for your great work.
R BCM 2007 no longer showing up within Outlook 2007 BCM (Business Contact Manager) 3
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
Diane Poremsky BCM Errors after Upgrading to Windows 10 New Slipstick.com Articles 1
R Installing BCM BCM (Business Contact Manager) 0
