How to use outlook 2003 calendar in always offline mode
2l8
Hi!
We want Outlook calendar to replace our paper booking calender at work. The problem is the security rules says that we can't have the computer connected to Internet. We can only us with locally. The idea is to use outlook calendar offline with its great functionality.
The IT-support says it's not possible but I say the opposite.
Please help me with this☺
Sent from my Nexus 5 using Tapatalk
C Forwarding Outlook 2003 calendar items Using Outlook 1
V Sync Outlook 2003 calendar to iPhone 4 Using Outlook 2
D Outlook Calendar 2003 Using Outlook 3
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
M Cannot open CALENDAR in outlook 2003 Using Outlook 2
D Calendar Permissions Outlook 2003, 2007 and 2010 Exchange Server Administration 2
F Foreign Accents in Outlook 2003 Tasks, notes and Calendar Using Outlook 4
P Exporting Calendar, Contacts & Tasks from Outlook 2007 to Outlook 2003 Using Outlook 5
T deleted my calendar from "My Calendars" in Outlook 2003 Using Outlook 2
W Syncing Hotmail Calendar to Outlook 2003 (SP3) Using Outlook.com accounts in Outlook 2
S Can Outlook 2007 calendar match the Outlook 2003 calendar? Calendar Printing Assistant 3
