outlook.com problems
Outlook on the web
Hi all,
I need to know some important information. I use outlook.com, for reference (a hotmail account).
Can the preview pane for viewing pictures give me a virus/malware/anything like that? And even though I turned it off, why is the preview pane still showing pictures?
I recently was on craigslist and I believe a scammer sent an e-mail that auto-opened preview pane (it is turned off, but it still loaded a picture preview).
I'm just very concerned about this work laptop with sensitive information.
Thank you for your time and help.
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
T Missing Folder in Outlook.com Using Outlook 3
dbjdbj Is it only me having a fun time with Outlook.com "beta" ? Using Outlook 3
I New Outlook.com Using Outlook 1
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
D Sharing outlook.com calendars in Outlook 2016 Using Outlook 1
M Can't send email in outlook.com Using Outlook 9
T BitDefender reporting outlook.com as 'insecure' Using Outlook 6
T Some of my folders in outlook.com appear to have vanished, thanks to v1803 Using Outlook 11
C Syncing on outlook.com Using Outlook 4
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
S Outlook.com cannot edit some contacts Using Outlook.com accounts in Outlook 5
B Outlook.com People Limits Using Outlook.com accounts in Outlook 11
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
M Mailbox Size Outlook.com or Outlook 2011 Using Outlook 1
C Long List Of Outlook 2016/Outlook.com Bugs // Where To Report? Using Outlook 10
M How many days are items in Recover Deleted at Outlook.com ? Using Outlook.com accounts in Outlook 4
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
W Cant connect to outlook.com from outlook Using Outlook.com accounts in Outlook 2
J Outlook 2016 and Outlook.com Using Outlook.com accounts in Outlook 1
J Outlook.com with outlook 2016 Using Outlook.com accounts in Outlook 2
D Outlook.com in Outlook 2016 Trys & Fails to Send on Behalf of Itself Using Outlook.com accounts in Outlook 2
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
M Mobile notifications and sync in Outlook.com Using Outlook.com accounts in Outlook 2
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
B How to get Meeting Invitations into Outlook.com calendar? Using Outlook 2
