Ex2010 problems with mail-enabled public folders
Outlook 2013 64 bit
Hi there,
I have set up pf replication and I want to decommission one of the servers because of its poor hardware. To check if everything is working on the new servers I have disabled replication on the old server.
Problem now is, that the users are not able to send mails to the pf anymore. They will be send to the old server. Newly created pf are working, mails will be send to the new server.
Any hints where to search?
Regards,
CK
C problems Using Outlook 1
P outlook.com problems Using Outlook 0
