cleaning up old Exchange 2003 data on Exchange 2010
drubin007
Outlook 2007
We decommissioned out Exchange 2003 Exchange Servers about a month ago. That was not a simple process and had to be completed manually (adsi edit) since the add/remove programs would not cooperate and we could not locate the original media.
It was somewhat painful, but completed.
I am running the Best Pratices Analyzer on one of my Exchange 2010 Servers today and coming across a few errors... Before posting this I did search the forum and this was the closest message I could find related to my issues:
https://forums.slipstick.com/threads/23895-msx-2007-routing-master
These are the errors I get from the Best Pratices Report: Routing Master has been deleted". I also see "cannot connect to port 25 of the routing group master and last one, cannot connect to port 691 of the routing group master.
On my Exchange Server if I run the command "Get-RoutingGroupConnector" there are no results found. I have been navigating all morning in the adsi editor but cannot find any additional references to the decommissioned Server(s). Where else should I be looking in order to clear up these "critical issues"? From all the research, they do not actually appear critical, however I would like to prevent them from appearing without selecting to not show this again.
Thanks in advance
Dave
drubin007
Outlook 2007
Have you seen this on the Routing master error: http://technet.microsoft.com/en-us/library/aa996552(v=EXCHG.80).aspx
Check using adsi edit: Configuration, Services, Microsoft Exchange, Domain, Routing Groups, Domain area. Check properties for the domain and remove the distinguished names for any routing groups.
Diane -
Thank you for responding.
I saw that link; when I used the best pratices analyzer it brought me to the same page. I do not have access to a console with Exchange System Manager (Exchange 2003) anymore to chang ethe master as that document states.
When I open the ADSI Editor on one of my Exchange Servers, I do not see a tab called "Configuration" . I thought this was strange so then went onto one of my primary Domain Controllers and found it there. This was good, however when I expand it, I do not see a Folder for Routing Groups. Could you be a little more explicit on where I could find this Folder?
I have been poking around (expanding different folders) to no avail.
Thanks again for your help.
David Rubin
icacream Can't the Deleted Items Folder be self cleaning ? Using Outlook 2
R Deleting Synchronisation of Old Accounts Using Outlook.com accounts in Outlook 0
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
Steven 2007 New PC vs Old PC - Micro Font on Inbound Emails :( Using Outlook 4
J Delete old emails Exchange Server Administration 1
J Old unread emails on current date (MDaemon Server) Using Outlook 1
J Outlook 2016 - use of old PST file - will all emails be downloaded or only latest?? Using Outlook 1
B Delete/replace old files and save new attachments Using Outlook 1
J Corrupt & new profile - old contacts? Using Outlook 2
A Updated custom form not showing with old items Outlook VBA and Custom Forms 2
C GoDaddy office 365 setup wizard erased old Outlook emails? Using Outlook 14
B Deleting old Stream_autocomplete and other files Using Outlook 1
J Automatically Move Old Items from a Shared Mailbox to a .PST on a Network Drive Outlook VBA and Custom Forms 1
P deleting old UDP items in tasks Outlook VBA and Custom Forms 3
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
B Old attachments do not open after Exchange 2007 edb recovery. Exchange Server Administration 3
P Restoring old sbb database in existing one BCM (Business Contact Manager) 4
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
K Outlook 2010 form is displaying old form layout Using Outlook 3
rezazy Do not download old email Using Outlook 1
R Can only see emails no later than two weeks old! HELP! Exchange Server Administration 6
R Can only see emails no later than two weeks old! HELP! Using Outlook 5
N User deleted old meetings? Using Outlook 1
L Messages in old PST display as code Using Outlook 1
Rupert Dragwater How to delete old rules and create new in Outlook 2013 Using Outlook 12
D Outlook 2007- old reminder popups Exchange Server Administration 4
P Installation BCM impossible due to untraceable old SQL-server remains BCM (Business Contact Manager) 6
R Rules - apply to messages > n days old Using Outlook 2
S old mail continues downloading over and over Using Outlook 3
Katrina Fox Missing appointments on calendar even though transferred from old pst Using Outlook 0
V Re-use old pst file? Using Outlook 1
J Old problems that never die BCM (Business Contact Manager) 0
Jennifer Murphy How to Copy Categories from the Old ANSI PST to the New Unicode PST? Using Outlook 4
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
S How do I keep my old PST file as default Exchange Server Administration 1
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
O Outlook keeps downloading old mail Using Outlook 1
R How do I move .vcs and .vcf files on to my new SSD from my old HDD Using Outlook 1
M Run rules after mail is 24 hours old Using Outlook 1
G Cannot retrieve emails past 2 weeks old Exchange Server Administration 1
S outlook 2010 only shows old email Using Outlook 3
