problems
Outlook 2013 32 bit
So i just starting using outlook 2013, and am not really sure how. When i was first registering, i got to a point in which outlook now sends me a message that says the connection to microsoft exchange is unavailable. I looked it up on the internet and it says to go into the mail option on the control panel i did so but it will not let me open and nothing happens..so what do i do?
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 10
