Will BCM work with any Office 2013?
Outlook 2013 32 bit
I have been trialing Office 2013 Professional Plus. Now that its time to purchase I'm wondering if I can go with the "Home & Business" version and still be able to install/run BCM. I don't need all the pieces of Pro Plus and it's significantly more expensive.
TIA
Michael
As far as i know, yes, it will work with all versions/suites. The core programs are the same, the only differences are which programs you get plus some features that require enterprise servers, like IRM, are missing.
I'm using it with Home Premium, Small Business Premium, and Enterprise. Well, i was using it - an update killed it and i haven't gotten it fixed yet.
B bcm and "Office 365 Home Premium" 2013 BCM (Business Contact Manager) 1
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
R BCM with MS Office Accounting... Simple question BCM (Business Contact Manager) 0
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
V Already have Office 2007 Prof Plus, want to get BCM BCM (Business Contact Manager) 4
J BCM I w2007 and Office 2010 Professional Plus BCM (Business Contact Manager) 5
D OEM Office Professional Trial w/o BCM BCM (Business Contact Manager) 1
S BCM in Office Ultimate 2007 Won't Install on W7 Ultimate 32 BCM (Business Contact Manager) 1
Y hosting BCM database at office online / workspace BCM (Business Contact Manager) 2
R Office 2007 SP2 Install: BCM Update Failure BCM (Business Contact Manager) 25
L RE: BCM Office Application Issue BCM (Business Contact Manager) 1
J Office Ultimate- My outlook doesn't have BCM, how do I enable? BCM (Business Contact Manager) 1
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
